![]() Join Date: Dec 2008
Built ka24det part out!!!
The car ran really strong, cruised around 14-15 on the wideband and 11.9 on WOT @ 20psi w/ no knock. No leaks, or over-heating, tested compression and it was 150psi on all cylinders.
Engine: All parts has 6000 or less miles on them -Wiseco 9.1 CR, .020 over bore pistons+Pauter X Rods-SOLD!!! -Rebuilt S14 Head-$140(PENDING) -JWT S1 Cams w/ JWT Adjustable sprockets-$520 shipped -Turbonetics t3/t4 turbo, .63A/R Stage 3 Turbine, no shaft play-SOLD!!! -OBX T3 turbo manifold+Custom made downpipe-SOLD!!! -OBX 44mm wastegate w/ 7, 14, and 20psi spring-SOLD!!! -CX-RAcing FMIC w/ 2.5" pipings+Blitz DD bov-SOLD!!! -AEM Water/Methanol Injection(smallest nozzle has stripped thread, but is currently on the ic cold pipe and holds just fine @ 20psi)-$240 shipped -Oil filter relocater-SOLD!!! -Topfeed Fuel Rail+60 lbs High Impedence Siemens Deka Injectors and injector clips(the fuel rail has been drilled the fit 14mm o-ring injectors)-SOLD!!! -Nismo Type-B FPR-SOLD!!! -z32 maf-SOLD!!! -CX-Racing 2 row radiator-SOLD!!! -Glow shift blue digital oil pressure, and blue digital water temperature gauge and glowshift fuel pressure gauge-$120 shipped for all three. -TXS Knock light-$SOLD!!! -S13 Calum Ecu-$SOLD!!! -Kennebell BAS-$220 shipped -Two sets of stock mounts-$25 shipped for each pair Please add 3% if paying by paypal, thanks. I can also deliver to the Bay Area and Fresno Area or any cities in between for a small gas fee. Call me at 530-781-3157 or email me at [email protected]. Here's some links to pictures: http://i130.photobucket.com/albums/p...30-09_1238.jpg http://i130.photobucket.com/albums/p...30-09_1239.jpg http://i130.photobucket.com/albums/p...07-09_0952.jpg http://i130.photobucket.com/albums/p...07-09_0954.jpg http://s130.photobucket.com/albums/p246/tekvang/ Last edited by tek_88; 09-06-2009 at 12:18 AM.. |
![]() Join Date: Jan 2005
Trader Rating: (31)
interested in the rods and pistons. how many miles are on them.
Slip Gypsies Blog Quote:
#9 | |
Trader Rating: (31)
pistons and rods sold to me
List update:
JWT S1 Cams with Cam gear-$480shipped Kennebell Boost A Spark-$200shipped Stock motor mounts-$15shipped or best offer... Last edited by tek_88; 09-11-2009 at 03:52 PM.. |
