help! s14 sr20det keeps turning off when coming to idle!
i need sum help ! my sr keeps on turning of when i down shift in to another gear or come to a stop when idle is dropping when put the clutch in. check all vacuum lines and all seem fine bov is good and i dunno wat the hell else it could be. happens the most when i put the clutch in and rpm is dropping hel please
#2 | ||
I have an s14 sr, and when I switched to a hks ssqv, I had the same problem. Just do what Slidin' said, and you'll be fine.
He said it happens when he pushes his clutch in... I'm guessing you've got a lighter flywheel and that's causing it to drop off... How to solve problem? Learn to heel-toe when shifting...
#14 | |
![]() Join Date: Jan 2005
Covering it up is a waste of money. |
Dude, you guys are so fucking off it hurts from all the laughter.. If the problem lied with his atmospherically vented blow off valve the car would be running rich and that would be causing the stalling but it isn't.
He clutches in and the RPM's die off. Why? Because his flywheel is too light and that's what happens when your flywheel is too light. If it dies just pop the clutch and the car will start again.. You bought the car already modded I'm guessing... |
#16 | |
