S13 need advise of frame fix?
So I got a s13, I traded a sr20 Ecu for it. Anyways I am swapping a v8 in the car and I was inspecting the car and came across a big problem, the tension rod bracket is welded to the frame rail. Only one bracket is welder but I inspected the problem and there is nothing wrong with bolt hole or threaded alignment stud so I do not know why they did that anyways I am thinking about grinding off the bracket and weld and possibly put in a repair piece. Let me know if you have any info or comments on other possible ideas and ways to repair the problem.
Thanks |
![]() Join Date: Feb 2012
Trader Rating: (37)
If both nut and bolt thread in their respective places, grind out the welds and slap on a new bracket.
I think that there is something wrong that you're not realizing to be honest. Who would go through that kind of trouble for nothing?
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
Yeah I was thinking the same thing, I looked and did not see anything obvious, will look around more tomorrow, my bracket on opposite side has a the internal frame nut spinning so the bolt and nut free spin so I need to re weld nut back on.
Thanks Richard |
