Quick SR wiring/ecu identification help
I just purchased an sr harness that is a mess.
The harness is said to come from an s14 chassis, with s13 motor. Is there a way to BE SURE of what harness i have before i start checking the wiring? I THOUGHT my harness was an s13 silvia harness because it seems to have the correct number of pin locations. However, i became confused to see a wire in the pin 38 location. (second to left, top row). When looking up pin 38, there is NO WIRE NOTATED there... EDIT- not sure if it helps, but there are TWO wires attatched to the pin 38 location...like they were for some sort of guage. So, how do i identify which exactly i have? |
![]() Join Date: Sep 2005
Are you try to figure out if it's not an s13 sr harness? Pin 38 for s13 harness is ECCS power, so yes they could have tapped that wire for a gauge.
vtc solenoid plug?
I just want to know how to identify WHICH harness i have.
Are there special marks, numbers, or number of pins? I'm assuming a s13 harness CANT be used with a s14 ecu, or visaversa...right? |
s14 has 76pins holes, s13 has 64 pinholes iirc. I forget
thats just something i noted, don't know how accurate that is though, I'll go count my pinholes Yeah, 64pins for s13sr harness plug
If you want to swap out for a S13->S13SR harness, I'm actually about to repin mine to go in to my S14... if it is indeed a S14->S13SR harness, we should swap
Oh, gotcha ~ well, sounds like you got the right one then
