Ka24de no crank
Just replaced my s13 de with another s13 de and i cant get it to crank i believe i have everything hooked up correctly. Is there something that i may have overlooked?
starters not clicking at all, but it was ckicking before the swap. brand new battery, and there are two plugs behind the engine near the firewall that arent plugged into anything but dont seem to have a place to go. I left harness intact before i swapped the motor
Need more details!!!
Ok, your starter work? Do you even have power at the starter? Just because the wires are connected, don't mean sh!t. MORE INFO!!!
Rock wha U jock and don't talk if U ain't got!! ![]() ![]() |
#20 |
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
Take a bunch of photos of your engine bay and post them to this thread, try not to be so stupid on the internet and give more info. DERP
DLG - DIRTYLOVE |
#21 |
Find your wiring schematic for the starter circuit. There shouldn't be much in between the battery and the starter. Typically the ignition switch, starter relay, neutral safety switch, and a fuse.
#23 |
ok, and yes before i swapped the new motor the prev motor before it blew started up with the 5spd swap. the starter worked before. ill double check connections and go to get starter checked.
#27 |
still no crank O_o i took some pictures of the engine bay, ill post them in a little. theyre from before with old starter but since that is now replaced with new one it has to be something else
