![]() Join Date: Dec 2008
Ok so maybe you guys can help me out with this nightmare lol.
I've been searching for about 2 weeks now. So car is a '90 hatch with a '93 engine/trans & ECU. When I first got the motor in I never bothered to open up the valve cover and check the cam timing. I figured it would be ok. But it apparently wasn't. Exhaust side was way off and when I hit the starter I was taking out valves . Afterwards re-timed it and did a compression test, wasn't too good.Cyl 1 - 115psi, Cyl 2 - 50psi, Cyl 3 - 90psi & Cyl - 110psi. Not good so I bought another head which came from a 95. While I was at it I replaced the piston rings and rod bearings and bought a cometic headgasket and arp head studs. Compression is now between 150-160psi. Plan on building up the original head to replace the '95 later on. Now that everything is better and all back together I can't seem to get it to start. I confirmed spark by cranking with a plug on top of the valve cover. Spark was yellowish however but the plug was old. I know I'm getting fuel because I can smell it when I crank and smell from the exhaust. Set ignition timing time and time again and its right on the money I believe. When its in and set at tdc the rotor is pointing perfectly at plug #1. And yes I made sure I set it one compression stroke. Its a little hard cause I have to tap it in there with a mallet. I checked the ecu for codes and I'm getting a code 11 (cas) & code 34 (knock sensor). I'm not sure if it would throw a code 11 just if the timing was off or not. I haven't been able to try another one. Also the PO had simplified the intake manifold a lot. There are only say 4 vacuum lines left. I know it was a little long but didn't want to leave any info out. Thanks in advance.
1990 Nissan 240SX w/KA24DE - New project 1984 Mazda RX-7 GSL-SE 13B Last edited by Pro ViZIon; 04-03-2011 at 01:33 PM.. |
Ok so I was so close. It was at the point where it would run for a few seconds or so , so I'm guessing the timing was off but my damn dizzy basically broke in half lol. So I need to get a new one now.
1990 Nissan 240SX w/KA24DE - New project 1984 Mazda RX-7 GSL-SE 13B |
uh if ur dizzy doesnt slide in easy then the idler gear bolt hole maybe ben or the bolt it self
on the ka its supposed to slide in smoothly..lol and when u set dizzy it has to point behind 1 when u slide it in then it rests at 1 if u understand that
シチサn w/ka20det:in progressシチサnw/sr20det:stolen |
Yeah when I set it. Set the idler a little back so when it goes in its at 1. I'll definitely be doing that when I get another one.
Here is a nice guide if you need it: 240sx Distributor Timing
If your engine doesn't run after you get the dizzy maybe look at your fuel lines, that was my problem: I could crank my engine and it would have random combustion every now and again. Here is a picture of correct fuel lines: Ka24de by vaioalii on Photobucket hope this helps somewhat, Andrew |
