Ca18det turn key swap 2k
Ca18det turn key full swap
Rebuilt motor about 1k miles Head, block machined decked and crankshaft polished Stock Pistons and rods Cosmetic street pro full gasket kit Metal cosmetic head gasket Acl race bearing Acl main bearings Arp head studs Oem piston rings Oem water pump Oem timing belt Oem tensioner Oem oil pump Aluminum pulley kit R8 coil pack conversion Ignitor chip bypass Wiring specialties harness Spec stage 3 clutch kit Oem flywheel resurfaced Jdm intercooler and piping Real Greddy bov Sr20 t25 turbo with adjustable wastegate Megan racing motor mounts Aluminum rad with silicone hoses Sr20 downpipe I want to 2k firm I have a lot more into this swap and it can easily push over 300 or more with the right supporting mods Buy it now and get ur s13 running |
| ca18det, s13 180sx 240sx hb, swap, turbo |
