![]() Join Date: Apr 2003
Stretched tires and drifting
I have a technical question.
On the back of my 14 I've 9" with 225/40/18, yesterday in the drift show in a "pendulum" (don't know if you call it the same..feint??), my sx rear tire goes inside on the wheel!!! damn!! fortunately no damage for the wheel, only a little scratch on the back of the sskirt..So is my rear wheels/tires combo wrong for drifting??here I see lot of people run stretched tire..any suggestion? |
#2 | |
i dont what you're trying to say
Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
![]() Join Date: Jan 2003
mmm, stretching tires usually depends on how good the tire is. if you stretch a shitty tire and try drifting with it that probably will happen. or have it mounted wrong, or have something freakish happen, like pebbles getting into the tire.
but no, 225/40 isn't that stretched, i've seen worse. like on a 10 or 11.
Paul Black and Red |
I've seen one time in an option video,the tires goes inside in the wheel and the air goes out..a inch of wheel remain out of the tire..damn in italian is easy! "stallonare"
I have think about pressure, but they would be at 2.5/2.7 bar (38/40psi) the tires is a new set of toyo T1rs, tire is ok, no bubbles or damage.. |
i use a 225 45 17 on my 9 inch wheel.
havent had a problem. does both rear tires leak? or only 1? maybe tire mounter messed up the tire bead. ![]() 225 40 18 on a 9 inch should be fine. no problems.
![]() Join Date: Aug 2002
what kinda of murble gurlbe was that? You should search first i think they made multiple threads about this. I didnt understand a word you said.
kick rocks. |
he is from Italy.
Not everybody in the world speaks perfect English, or any English at all for that matter. Why don't you go post a response in Italian and see how perefect it is?
WOW addicted
![]() Join Date: Dec 2001
I'm running 215's on a 9" wheel and have had no problems. was it 38-40 psi cold or hot? It's possible that if they were 40 psi hot, and you were drifting, they could get to 48-50 psi which could very well have gone beyond the maximum psi for the tire.
i currently run a 215 on a 9 (17 inch)
stretched tires is fine, just gotta be careful, and make sure who ever is mounting it knows what the hell he is doing
#14 | |
X - QUEEZE ME ,
I didnt see that. Shame on me, apologies. Quote:
kick rocks. |
Sorry for the english, I've search but is almost impossible translate some words..
when the shit was happen I'm on the track,so very high grip, but first run so not too hot..first thing I've think is low pressure..this week I'll go to the tire shop for hear what they think..Now i'm sick,damn.. |
#16 | |
they might have just messed up the bead of the tire when they installed the tire onto the wheel. I dont know if you have ever installed tires before, but it is hard to put short sidewall tires on, and sometimes you might rip the bead when putting it on. That might be what they did.
(I tried to type as clearly as possible)
#17 |
![]() Join Date: Mar 2003
its gotta be with the seal/air pressure
i have that problem on one of my 245/40 on occasion need to make sure when they mount the tire they use a cheater(high pressure air nozzle) |
#18 | |
isnt that what everyone uses to pop it onto the rim properly?
where you put it thru the valve stem w/ no core and then just...pop it...that's how i've always mounted them anyhow
#19 |
![]() Join Date: Mar 2002
No a cheater is a tank and it blows XXX amount of PSI into the edge of the rim to set the bead. Sounds like you're just filling it thru the valve stem without the needle (core?)?
Go big or go home!
#22 |
![]() Join Date: Jan 2004
well hard tires would givbe the sucky traction that stretched tires give, would be stiff, would look wider, and would still be cheap cause they'd be sucky tires. i asked a question and your answered with a metaphorical "piss off".
now how's about we have a nice and rational discussion here? |
#23 |
shitty tires and drifting result in destroying your car because of hitting a wall, curb, mountain, other car, etc.
If you have no idea about drifting, dont fucking post anything.
#24 |
so if a stiff sidewall and ability to break free easily aren't the intended benefits of stretching tires (outside of clearance reasons) what are the actual intended outcome of such a ridiculous look?
#25 |
I think in this case, our Italian friend is running into a maximum tire width law in Italy. (I remember him posting that before..) However, he has some nice wide wheels that he wants to sport, so he has to stretch 225's on them since that's the max the law will let him use on an S14.
Thus his need to stretch tires. I'm sure many others do it for mostly aesthetic reasons - the "jdm tyte" look, or something like that. To each his own, I suppose. |
#26 | |
![]() Join Date: May 2002
name me a wide tire that has a stiff sidewall and not ridiculous sticky please. when you really drive you find tires are mostly: sticky with stiff sidewall, shitty w/ soft sidewall, something in between isnt too common at all. there are ways to make it work, with various types of stretching (crazy or simple) a 235/40 on a 17x9 isnt much of astretch at all a 235/40 on a 17x10 is you use what tires you have but you would know, just hard parking. you have no first hand expirience. stfu. |
#27 | |
Yeah so. You asked a question to answer the original poster's question which doesn't help him. Now most people are dicks about this subject cuz they don't have any experience, so I didn't expect your attitude to be any different. My interpretation on drifting is to exceed the point of your grip angles (exceeding traction, but being able to maintain it) and having decent grip tires to do it is right. Meanwhile if you use low traction tires, you can't go as fast because the traction isn't there and controlling the slide can be funky. There's a misconception of drifting without traction, when actually it's quite the opposite. So soft tires = good traction, stretched = good break away. By the way, hard tires do not equal stiff sidewall.
Go big or go home!
#28 |
Admin Asshole
Excellent info here guys, keep it up. This is starting to smell like a FAQ.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#29 | |
Toyo is one of them, some model Falken have problems as well. So far Yokohama has been the best tire we use that had no problem. You might want to try different brand of tires until you find the model/brand that will work best for you. Good luck, Sam
Nissan Japan: "road to happiness has many curves" Jdmlivin: "Jdm is dead, the yen is crazy"
#30 |
Thanx all guys!! very kind reply, unusual on zilvia
Is right that, I have to use 225/40/18 'cause is the maximum we can put on a s14! and I've toyo 'cause they give me it gratis, for have my car on their stand.. In my little experience I've understand the difference in drifting with bad tires or with good one! Toyo T1R had maybe too much grip, it for track not for drifting, but is also true that you have a total control in sideway!! and this is awesome! with the old tire the car loose control easily.. Friday I'll go to the tire shop for control the tires.. ![]() |
