![]() Join Date: Mar 2011
Problem starting sr20det in s14
Hi everyone my s14 just clicking like I can hear it at the relay all the cables seem to be on the starter fuse is good . I did put battery in trunk mybee I messed the grounds up should I reground everything under the hood why should I do to check the starting system any help appreciated thanks
