![]() Join Date: Nov 2011
no oil pressure to cams, but oil pressure to head
Another problem, my oil squirters for the cams arent spitting out oil. I blew air through them and they aren't clogged. I pulled off the valve cover and had my buddy crank the motor while I watched them, oil spewed all over the back of the engine where the oil squirters bolt down too, but no oil THROUGH them.
My question is, is there some sort of banjo bolt you're supposed to use with these? Because if the squirter gets oil from that bolt, aren't we 'plugging' that hold up by bolting down the cam cap? I assume I have the right bolts because they are slighter taller than the rest to compensate for the size of the banjo on the squirters. I think this might have always been a problem, I just didn't notice it until now. So, why is oil spewing out of the place where the oil squirter is bolted, and not letting oil through the actual feed? |
I believe the bolt for the cam cap has an undersized shank that allows oil to flow up and around it into the "banjo". When you tighten that bolt down it should seal oil from "spewing" out and force it through the squirting rod. I can't recall if there is two washers for that "banjo" fitting or not, but make sure it's torqued correctly and making the "banjo" tight to the cam cap. If not, find a washer in there to take up the slack. Remember, fluids and air travel in the path of least resistance. If there is a way out, it'll find it.
My SR20VET |
![]() Join Date: Jul 2005
Just a word of caution, did you note the size of the holes in the camshaft oil tube? Not very large are they?
They clog easily. When your valvecover is off, and you lean over the engine and drop a bit of (random insignificant junk) into the engine, that could wind up clogging one of those tiny holes and it will wipe a cam lobe out and the engine will be ruined. Make sure everything is as clean as you can possible keep it. |
![]() Join Date: Sep 2005
Why\How does destroying a cam lobe equal a ruined engine? Just curious!
Normally what happens after a cam lobe dies is the noise from the lobe hitting the rocker, followed by the crazy clacking sound. So again, there's nothing you can do to save the engine, it's just done for?
I think it was a little bit of an over exaggeration in his part.
My SR20VET |
#8 | |
You think that even if you pull the entire engine apart, hot tank and wash it, that you will get all of the metal out? If you've ever actually wiped out a cam lobe on an engine, and tried to "fix" it by replacing the camshaft/rocker, only to find one week later that it mysteriously happens again because some mysterious metal from "somewhere" clogged up another cam oil hole... |
