ok so I bought some calipers rotors master cylinder for my s13
Front is no problem now I know you need the rear spindles lower control arm and z32 rear shocks/coils for everything to fit at the back with e brake My question is by doing this can I swap out the 5 lug and slap on my 4 lug I do not want to change rims that is for sure and I want to be able to have z32 brakes all around with the ebrake What are my possibilitys and options ? Thanks in Advance for all the input |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
You do NOT need Z32 rear spindles, lower control arms, or Z32 rear shock/coils for an e-brake assembly to fit in the back of an S13.
Whoever told you that is talking out of their ass. Google "Z32 brake swap". The FIRST result is a "how-to" for everything. You can run 4-lug all around. Just need to re-drill all of the rotors for the appropriate lug pattern. |
#3 | |
ok I see it more in detail now, thanks, the person told me to take the spindles instead of wasting my time at the junk yard undoing everything there |
