Guest
Posts: n/a
I'm building a KA turbo with all the good stuff but i need to know where to get a good deal on pistons, rods, rings, and other nessascy interals. thanks for your help guys!
In my opinion JE manufactiors the best forged pistons on the market. They offer forged alluminum pistons with all sorts of compression ratios. Cower makes a good con. rod but any well manufactied rod from a repuable company should work fine. Tell them what you are using it for and they can direct you futher.
![]() Join Date: Jul 2001
14.0:1 is the ideal compression ratio you want to use for a turbo setup
ok i'm lying. 8.5:1 (or somewhere around there) is what the average turbo setup has, with aftermarket pistons. |
![]() Join Date: Nov 2001
Hmm...take the hood off and rev that sucker hard enough that the pistons will shoot out into the air. It'll be sorta like the 4th of July. <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
