Timing Chain Kit
Hey, been searching the forums for a few days but have not seen anything regarding a specific brand to stay away from or buy in regards to a timing chain kit. Most of what I have seen either links to an older thread about buying the individual parts and doing it yourself or how to do it. I will also apologize right now if this is not the right section, I was thinking possibly reviews, but that was mostly for reviewing people and businesses I thought, and I also didn't see a "create post" button.
So, my question is, has anyone purchased a timing chain kit for the S13? If they have, how much, where did you buy it, and what are your thoughts so far. Will be putting in a new timing chain and wanted to make sure that I didn't get a bad deal or a bad chain. My current top option is from O'Reilly for a Cloyes Timing Chain Kit for 159.99 + tax. I have heard one good thing from a friend who has used it. Thanks for your advice, will always stay a member. |
Stay away from the rock auto kit. Simply because when i bought their sun power kit, (I forget what the gear is called but its the one where all the other chains come together and drives the distributor and the cone was missing to drive the distributor). Rock Auto was cool they returned it and gave me my money back, but what was annoying is that Rock Auto and Sun Power kept telling me that what they sent me was correct. They were wrong I ended up buying a much cheaper one off ebay. I forget the company and made sure the gear was their to drive the distributor and when it was shipped to me all the parts looked solid and my 240 is running good. Just remeber to throw away the chain guides for the cam chain they make noise.
the osk one is decent, frsport
but honestly just piece it together with oem shit is it for the ka or sr? sr they have on frsport as well, oe, KA theres a thread on nico that helped me. part numbers and everything you need, pretty sure nissan still has em
street dancer. |
Yea, I got mine off of frsport. Two later, still no issues.
http://slidewell.tumblr.com/ |
It's KA, but I did the price comparison between the piece together and buying a kit, and even the O'R has become cheaper. Just took the numbers and priced it out quickly from the Nico Thread, and if I leave out the guides it comes out to $179.52. I have read that leaving out the upper guide is good, even recommended by Nissan, but should I leave out both or just that one? If the quality from Nissan is better than a kit, I don't mind spending the little extra, but I want to make an educated buy. If the OSK one is good, I may go with that, but compared with OEM?
![]() Join Date: Jan 2010
I got mine off of ebay, timing chains, gears, tensioners, guides and lower cover/oil pump.. 145 shipped for everything. Its been working great for about a year now with no weird noises or anything.
#9 | |
![]() Join Date: Jul 2010
Sent from my T-Mobile G2 using Tapatalk
_____________________________
just search "ka24de timing chain kit" in ebay and pick the one that fits your model year and chassis. I don't remember who in particular I bought it from but its all the same generic crap lol. I'm pretty sure I just bought the cheapest kit.
![]() Join Date: Oct 2006
Got a J and A or maybe it's JNA timing kit, all parts included. Cam gears, upper chain, lower chain, crank gear, upper and lower tensioners, and lower chain guides. Seems like it was about $265? Can't remember really. . .
i wouldnt buy ebay stuff... especially the lower guides... if anything buy whatever you want from ebay or wherever and get the oem lower guides. there is just some stuff you cant skimp out on. this is one of them. pay once, not twice.
"My car got into a fight with a 18 wheeler, and the truck won." |
One thing I have learned by searching some of the reviews of companies is the Mizumo is a no go as far as an eBay company goes. From what I read on the Subi forums, one guy bought their timing chain kit and less than 2 months later it was broken. One reason why I am not sure if I should go with an eBay one is because of reviews like this that I read.
One final question, then I plan on making a writeup for everyone. Is getting a new oil pump recommended, needed, both, or neither? I understand it will depend on the condition of the current one, but for users like me who bought the car from someone and has no idea what they have done, I would like to be prepared for when I do this and plan on trying to put all of this information in one place once we are done to answer this question for all those who are like me.
When I did my timing chain kit I replaced the oil pump because I had the lower timing cover off anyways. The chain tensioners operate using oil pressure, so if you have timing chain rattle thats likely part of the problem. Also, when I did all this I pulled the motor out of the car for easier access to all the stuff, took two days.
I am getting a friend's help with this, so I am not sure what I will actually be getting. His grandfather owns a shop, so best case is that we get free access to it and use of it with help. Worst case is we have to do it out of his garage and leave the engine in. Is it pretty much impossible to put the pump in without pulling the motor?
#18 | |
#19 |
![]() Join Date: May 2009
![]() Feedback Score: 20 reviews
i got a ebay one, installed it to spec.. works great so far, no chain noise or any slack anywhere. but if you have the cash call a dealer and get all OEM stuff
on doing it in the car.. http://www.harborfreight.com/1000-lb...:referralID=NA use this and just drop the subframe, it will come down just enough to get the pan out and do what you need to do, i used to check bearings on almost every car at the shop because it takes like 30 min |
#20 |
I went with OSK from the nice people at FRSport. Its pricey compared to the ebay kit as it does not include new gears, or an oil pump(which i wouldnt trust off ebay anyway)
But the kit is quality. Easy to install, weighty chains. |
#21 |
Final conclusions
So, after reading this, I have a good idea of what is good (or not by the Subi forums), but just in case someone else needs it sometime, I am going to post prices and links for what seems to be the best timing chains and their prices.
Information about the swap/repair. I used this site to get the prices. Parts individually. $297.77 (after tax and shipping in CA) Timing chain kit from O'Reilly. $172.39 (including CA tax), can be picked up at store or shipped at no cost if ground. Timing chain kit from FR Sport. $210.06 (with normal, aka free, shipping and tax in California.) $194.95 For just the part with no tax. eBay. $57.82 to $275.00, but it is an eBay kit. Subi owners have had lots of problems with Mizumo parts, so buy carefully. Dinosaur. $203.64 with no tax and shipping. (Tax in AZ) Support bar. $87.42 (including tax and shipping to CA). Useful if you are planning on doing it all at home. Overall, the O'Reilly is the cheapest (not including eBay kits) and I personally know someone who is running it who recommends it. The people that posted here have had their FR Sport ones in for a while and have had no problems, and is only slightly more expensive for something that has been shown to work well. If anyone else needs to do this, hopefully this will help decide. Please let me know if there are any notes that you think I should include for this. I want to make it as detailed as possible to help people make an informed decision. Also, if you see anything wrong or that you think just doesn't sound right, let me know. I will try to call Nissan today to see what the prices are like, so I will update if I can get a clear number from them. |
#24 |
Frsport is great they wont ever do you wrong.
this stuff helped me do mine the first time.. itsapretty easy job. The thing thats going to be hard is getting the crank pully off. you should rent the tool from autozone to make your life easy. And make sure you have plenty of silicone, i like ULTRA GREY. i swair by it. when you have your oil pump off you can take out a few wide philips scrwes and you can take out the oil pump gears and clean them. i cleaned them off and added alittle assembley lube. this is a good time to clean and paint the upper front cover and oil pump. i used a nice silver.. HOW-TO: Fix Your Timing Chain Rattle : Nissan Articles wtbarrow s13 93 service manual |
| advice, chain, kit, review, timing |
