| Media Forum / Pictures / Videos Forum dedicated to media, such as pictures and videos. |
My BMW rockin the SR20DET.
For the record, I do all my own work except the tig welding.
H&R race springs, bilstien sports, koni sway bars, Mason engineering aluminum front and rear strut braces, Mason aluminum x-brace underneath, custom 304mm w/4 piston 3000GT vr4 calipers, rear disc swap, Power Slot rear rotors and Hawk hp pads, M3 rack and aluminum control arms. Powerflex bushings throughout, serious weight reduction, 2210lbs on the scale,(doesnt even have a heater) one Sparco seat. Kelford 260/11.7 intake 266/11.2 exhaust camshafts, Tomei heavy duty springs, titanium retainers, Powerbond crank damper, aluminum pullys, Greddy 5.5 litre aluminum pan, Z32 MAF, 740cc NISMO injectors, Garrett 2863R .64, KS racing top mount manifold, laminova liquid to air intake manifold/intercooler, Splitfire coil packs and ignition box, Jim Wolf Technologies ECU tune. ACT unsprung clutch, 11lb flywheel, nissan patrol slave cylinder adapter to bmw clutch master. 4.27 gears from a 91 525i. Torsen lsd center from 99 Z3,no name short shifter. 17x9 TD prorace wheels w/245/35/17 Toyo R1R At 15 lbs boost it will BLOW the tires away in third gear. It handles so neutral with the all alloy engine its just goes faster and faster though the corners. Actually rides quite well. I drive a 2 mile gravel road to get to the main road. Take care! Last edited by E30Napalm; 08-30-2012 at 09:14 PM.. |
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
thats awesome man...love that manifold setup!
do you have a hood with a hole in it or something or do you rock it without a hood?
https://instagram.com/eck_matthew/ |
This is refreshingly creative, I love it. What would be absolutely awesome is taking some footage of this thing in action. Once again props on creativity I wish I saw more cars like this on the daily.
#26 |
Love the manifold. I've seen a few laminova manis cropping up now. I'd be very interested in the performance back to back with a traditional FMIC.
