Old 02-13-2012, 10:07 AM   #4561
Chamb-O
Chamb-O's Avatar
Chamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the rough
Originally Posted by TheBlackNasty View Post
Looks like nice fab work buuuutttt all that porosity and burn through doesnt help your flow either, and looks like hell. You ever heard of running some argon purge? cork each end with a .25in hole for purge entrance and exit, run the argon at 20cfm and the inside will look just as tits as the outside...
thanks for the tip
Yep, unfortunately I am dictated by my means. The shop I work for wont pay for a second regulator setup so I am stuck doing this. I have purged before but I had to run the 75/25 out of the MIG bottle to purge, it actually does pretty well. The color turns to like a golden haze on the inside. I usually only purge for anything pre-turbo, IE Subaru up pipes, manifold repair, ect.
+1 on the auto fab crap
most people in the industry cap out at making under $20/hr
at least around this part of the country
Chamb-O is offline   Reply With Quote
Old 02-13-2012, 10:22 AM   #4562
Chamb-O
Chamb-O's Avatar
anyway
more fab pics
yet another Subaru 3" blow through MAFS
240 cat
Haven't had to make one of these in a long time
Magnaflow cats have a 3in ID and so do my flanges
Had to stick the end in a bead roller with 2 flat dies to turn it down for a slip fit
an old jig I had laying around
look no black nasty, TheBlackNasty hahah
no purge just a slip fit and heat control
Old 02-13-2012, 03:35 PM   #4563
D.Adams
D.Adams's Avatar
Picked one of these up today
I made a bumper for a friend this weekend also threw some support tubes in the rear subframe of the 240.
the rear subframe on the 240.
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover
The build
Owner of NVS Fabrications
Old 02-13-2012, 03:41 PM   #4564
Tanuki
Tanuki's Avatar
Tanuki is an unknown quantity at this point
Here is my cage I just constructed over the past 2 months. I really do not know how to count the points, but I guess it is a multi point. Hand made, not based on any modified kits etc.
DOM 1.75" tubing. MIG/TIG welded.
Tanuki is offline   Reply With Quote
Old 02-13-2012, 04:11 PM   #4565
defcon86nwh
defcon86nwh's Avatar
defcon86nwh is an unknown quantity at this point
I love this thread.
Sent from my ADR6400L using Tapatalk
defcon86nwh is offline   Reply With Quote
Old 02-13-2012, 04:32 PM   #4566
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
why is there a bend in that halo?
TLDR
Cliff notes: Florida
sr20sean is offline   Reply With Quote
Old 02-13-2012, 06:43 PM   #4567
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
Clear the mirror or tuck it closer.
SW Fab
shiftdrift is offline   Reply With Quote
Old 02-13-2012, 07:14 PM   #4568
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
Hey are 1/8 plate are sufficient enough for floor plates? Remember I have a bolt on cage.
NEED Bolt kits for your car?
Old 02-13-2012, 10:43 PM   #4569
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Bolt in cages are not safe.
In a weld in cage 1/8" is fine if you have sufficient coverage.
1/4" for land speed cars.
blu808 is offline   Reply With Quote
Old 02-13-2012, 11:06 PM   #4570
blu808
blu808's Avatar
BMW E36 M3 Formula D car.
CNC cut radiator support.
Removable on sheer bolts.
Removable tow hook.
Removable aluminum crash bar.
Rear fuel cell, battery tray, jack point, strut tower brace, subframe connection.
Old 02-14-2012, 01:29 AM   #4571
godrifttoday
Trader Rating: (82)
I welded the plates on the car and then bolted the cage to the car with an additional 1/8 plate in the bottom
File Type: jpg ImageUploadedByTapatalk1329208165.498719.jpg (120.5 KB, 130 views)
Old 02-14-2012, 02:51 AM   #4572
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
blu808, always sick work. love it when people are smart enough to make a bash bar/core support removeable...alot easier if you need to replace it or need to pull an engine out.
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 02-14-2012, 01:11 PM   #4573
TheBlackNasty
TheBlackNasty is an unknown quantity at this point
Originally Posted by Chamb-O View Post
anyway
more fab pics
240 cat
hahaha i see a little burn through! lol jk looks nice man, for no purge, i bet you if you use a litte more more rod and space the beads more (both to cool the weld more) you wont see aannyy at all! So you say in the auto fab industry the cap is low like that?? i guess the only way to get in the money there is to start my own r&d shop then
the field i am in some guys can get up to 40 50 and hour here in the bay area, after like 15 years or so.
TheBlackNasty is offline   Reply With Quote
Old 02-14-2012, 01:32 PM   #4574
Tanuki
Tanuki's Avatar
The bend is to follow the shape of the roof like it suggests in the NASA rule book. It also gives you much more visibility and in a roll over it will keep the cage from crushing in on you.
Old 02-14-2012, 02:14 PM   #4575
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
Bolt on panhard bar bracket I made
Gusset on one of the frames I'm building
SW Fab
Old 02-14-2012, 06:26 PM   #4576
godrifttoday
Trader Rating: (82)
Is that pulsed?
Old 02-14-2012, 07:56 PM   #4577
TheBlackNasty
Lol, looks like mig my man.
*Damn really? Never used very high end mig machines I guess.
Old 02-14-2012, 08:02 PM   #4578
Jonnie Fraz
Jonnie Fraz's Avatar
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Send a message via AIM to Jonnie Fraz
You can pulse MIG.
Looks like sandard cursive "e" pattern to me...please correct me if I am wrong.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 02-14-2012, 08:29 PM   #4579
Chamb-O
Chamb-O's Avatar
thanks,
that was based on my buddy who built cages for someone...he had like 10 years exp...he works for the Sheriff now hahah
the guy I replaced started his own business
shit I'll give him a plug Mo-Fab
pretty sure he capped out about that...he had been working for that business for 7 years, and been fabbing for longer than that
that is probably the way I will go in a couple of years, I have only been in the biz for 2 years now
Old 02-15-2012, 08:53 AM   #4580
atutt
atutt's Avatar
atutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond repute
I'll stick with my new, non-welding career, making $85,000 (it'll be bumped up to $90,000 before I get there) after 3 years on the job, lol
40-50/hr after 15 years is just to damn long. I got shits to build.
atutt is offline   Reply With Quote
Old 02-15-2012, 09:16 AM   #4581
onehundredoctane
onehundredoctane's Avatar
That catalytic converter jig is nifty, may need to make one up for myself so I can put a cat on my S14 and get the sound down and help me pass the tail pipe sniffer too.
Old 02-15-2012, 11:52 AM   #4582
godrifttoday
Trader Rating: (82)
And what is it that u do now? Abutt
Old 02-15-2012, 02:19 PM   #4583
atutt
atutt's Avatar
Law enforcement...
... But I think I'll always be a welder at heart. I can't escape that no matter how hard I try.... Considering 90% of my posts on Zilvia are in this thread, lol
Old 02-15-2012, 04:07 PM   #4584
blu808
blu808's Avatar
Just picked up some new welders for the shop.
Miller Dynasty 200DX Tig
and
Miller Millermatic 212 auto set.
The first time I used a 200dx was when Jonnie Fraz came down to my shop. He had just purchased it. The first weld I ever laid down with it turned out to be the best I had ever done. The arc shaping and control are superior to any machine I have used. I look forward to showing everyone what we create with these exceptional machines.
Luke
Old 02-15-2012, 04:12 PM   #4585
Jonnie Fraz
Oh Nice! You picked one up. You have wanted that for a while.
Old 02-15-2012, 08:56 PM   #4586
TheBlackNasty
and
Luke
NICE, I have been wanting to get that little tig set up for a while! what did you get that one for if you don't mind me asking??
Old 02-15-2012, 09:02 PM   #4587
TheBlackNasty
I know what you mean, Im desperate to get a few tools out in my garage and explore some ideas, im not cut out to be in law enforcement; too many illegal extra curricular activities.
Old 02-15-2012, 10:38 PM   #4588
blu808
blu808's Avatar
TheBlackNasty: We got a good deal on the pair.
I actually played around with the arc balance and wave shaping tonight. I have to say I am impressed with the cleaning ability of the machine.
I will post up some pictures tomorrow.
Old 02-16-2012, 05:21 AM   #4589
NismoPlsr
NismoPlsr is an unknown quantity at this point
So jealous of that Dynasty setup. Perhaps someday, but I'm not sure it makes sense for a "hobbyist".
S12 || KN13 || S13 || B16
NismoPlsr is offline   Reply With Quote
Old 02-16-2012, 07:02 AM   #4590
Acidz
Acidz's Avatar
Acidz is a jewel in the roughAcidz is a jewel in the roughAcidz is a jewel in the roughAcidz is a jewel in the roughAcidz is a jewel in the roughAcidz is a jewel in the roughAcidz is a jewel in the rough
4inch downpipe with dumptube almost complete.
also an rb20 manifold im working on
Acidz is offline   Reply With Quote
