SR20DET won't rev past 1500
Dropped a wrench on the battery for a quick second and now the car wont rev past 1500. I've read that if you bridge a battery while the car is off all you do is kill the battery.
I have: z32 maf 550cc injectors rs enthalpy rom tune I opened up the ecu and made sure nothing fried in there. Also redid the grounds and tested them, they came out all good. Tried unplugging the maf and running it, same issue. Thanks in advanced |
![]() Join Date: Dec 2011
sounds like the MAF or MAF wires could be bad. Not sure, but when i couldn't get above 2k rpm, i unplugged my maf, cleaned it, and replugged it. worked fine.
![]() Join Date: Jun 2013
Trader Rating: (25)
![]() Feedback Score: 25 reviews
Just a tip, Not too sure but it could be in limp mode. Try resetting the ecu.
If not its def. the maf ,Had a similar issue with a maf and wouldn't rev past 2500 and sounded like absolute shit |
![]() Join Date: Jan 2010
This sounds really simple but, have you checked the fuses in the engine bay? I know when I grounded something out I popped the main 75A fuseable link thats in there...
UPDDATE:
So i just read the ecu's codes. Came up as 55 which means no codes if im correct. Now im going to clear the ecu anyways and see what happens while i wait for my buddy to bring the other z32 maf. Any other suggestions? |
Trader Rating: (25)
(55)=all clear. You are correct. Hows your engine harness? The reason I ask is because a really messed up harness can give you all sorts of issues, and the ignitor is not the issue.
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
spend the money and invest in a datalink cable! download ECUTalk or find someone with NISTUNE. both of which will give you a read out of every functional sensor on your car! it majorly helps with tracking down bugs likes youre having!
#15 |
UPDATE:
Figured out the problem. One of the splicing on the maf wire (not ground) had come undone. And dropping the wrench on the battery had nothing to do with the issue, it was just a huge coincidence haha. Thanks for all the help guys! Oh btw, after redoing the grounds and sanding the contact points, the car runs so much better and doesn't die out any more. |
