Fuel System Problems
Alright so ive been confused about my startup problems and we decided to give fuel pressure test a go, im getting 25 pounds when it kicks on the fuel pump but when it gets started(Either by pumping the gas or ether) itll kick up to 43 pounds(normal psi) Is it supposed to be always at 43psi? and is this normally a fuel pump problem?
