#33 |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Stock long block
GTI-R at 7psi 370's N60 PSM HMIC Calum RT ECU Car runs consistant 13.4 @ 102's Soon to be running 15psi, meth, and n62 mafs Running at a local meet |
#34 | |
![]() Join Date: May 2009
![]() Feedback Score: 20 reviews
haha |
#36 |
![]() Join Date: Sep 2009
Hey guys I was looking for a good quality top mount and ran across a company named strk enterprises. Anyone every heard of them? Or are they some janky company that just copied the Full Race twin scroll..
(pic from their site Exhaust 240sx - Performance Service & Fabrication :: STRK Enterprises) ![]() |
#39 |
old setup...in a way i would have liked to have seen its full potential with a 6262 or something similar. Either way...moved on to bigger and better things.
Forged short block P&P head Kelford 272's SLS mani Bullseye 50 trim with upgraded wheel D-Werks 750cc
#40 |
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
KILLER THREAD IDEA...ITS ABOUT TIME!
I'll post some pics of my buddies tomorrow. love the KA-Ts on here so far!
https://instagram.com/eck_matthew/ |
#41 |
![]() Join Date: May 2007
well by the end of the summer i should be able to post in here. shooting for 300 ft/lb on a t25. with me luck lol
to be faster you have to slow downWTB OEM SILVIA AERO SKIRTS!!!!!! PM ME |
#42 |
![]() Join Date: Feb 2009
build in progress
6262bb ID2000s kelford 272s fully built aem ems z32 trans z32 diff j30 axles bc racing coils blah blah blah new intake mani will come after first 500 miles and bugs are worked out almost done finishing up the little things at the shop and then dyno time.. ![]() ![]() ![]() ![]()
![]() JUST A RED TOP SR Last edited by newslidz; 06-24-2011 at 12:30 AM.. |
#43 |
jholman05- yea its crappy quality but here is a little vid of your car putting the work in on the v8 rolla
YouTube - ‪video 2011 06 16 21 32 54‬‏
![]() JUST A RED TOP SR |
#45 | |
Ahhh thanks! |
#47 |
![]() Join Date: Aug 2009
YouTube - ‪SecondToNone aka. Yogi Bishnu 1998 240sx turbo Ka24de on Pump Gas 23PSI 457WHP‬‏
Engine Built KA24DE Arias pistols 8:8:1 compression .20over K1 rods Clevite Bearings Cometic Head Gasket ARP Bolts for everything Built head Brian crowler stage 2 cams Port and Polish Supertech Valvetrain Motor was put together by professional Machine Shop Garrett gt3071r twin scroll turbo Tial 44mm Wastegate Tial 50mm Blow Off Valve Full-Race twin scroll manifold (Ceramic Coated) Full-Race Ceramic Coated downpipe Metal z32 custom Maf Housing Z32 Maf Blowthru setup Apexi dual N1 exhaust Xcessive intake manifold Copper turbo manifold gasket Heat reducing Intake Manifold gasket Q45 tb Megan motor mounts Nistune ecu Dual fans with shroud Mashimoto Aluminum Radiator Greddy Intercooler Custom ducting for maximum airflow through radiator Battery relocated to trunk 1000cc precision top feed injectors Aeromtive fuel reg Top feed fuel rail -6 lines all way back to 255 walbro fuel pump Excedy twin disc clutch and flywheel setup Car made 460whp on 93 octane 516whp on race Silicon Rad Hoses All lines Steel braided Oil catch can AEM filter for turbo 3.54 rear end gear swap from Q45 with stronger axles and LSD Working on installing a trunk mounted meth kit. |
#48 |
![]() Join Date: Jun 2008
Lets not get too far off topic here, but I made 300/300 on my redtop sr20 with stock maf and injectors. I don't see it being too hard on a KA. The turbo just wont last very long.
#49 | |
![]() Join Date: Jan 2007
#52 |
alright, sweet lol.
this was like 2 motors ago. its way cleaner, but dont have any pics of the latest setup. what the setup was in this picture stock internals ![]() t25 370cc's nistune ecu stock maf MLS headgasket arp studs buncha maintnence fuse box is now tucked, battery relocated, bay painted, and all around wayy cleaner. building a new motor currently. fuck stock internals. |
#53 | |
![]() Join Date: Sep 2002
I'll throw a couple different pic up to keep on topic.
'11 M56S '12 QX56 (wife's) |
#55 |
http://garagemakeshift.blogspot.com/ |
#56 |
Very nice setup, what tuning are you using?
#59 | |
![]() Edit: done, check it out.. and you wont get flamed. its still KA-T also, this (per the rulezzzz) |
#60 |
![]() Join Date: Nov 2007
Trader Rating: (36)
![]() ![]() ![]() Feedback Score: 36 reviews
The evolution:
Semi-stock Ghetto Slightly less ghetto Awesome Of course this was when I had lot's of this... Here is me racing a bolt on srt-4 on 13 psi with my dying .50 trim (slightly less ghetto setup). http://youtu.be/Mw9Fj7kcHew Here's what an RSR Exmag sounds like on a ka with a large turbocharger... (awesome) http://youtu.be/PVTBit642SM The rundown: 100% stock s14 ka24de 72k original miles, turbocharged at 80k Precision HP 5862 57trim .63 a/r Nismo 555cc injectors JGS tools log manifold Full 3 inch exhaust (excepting 2.5 inch JGS 02 housing) HKS ssqv v2 black Tial 38mm wastegate Enthalpy Rom tune 18psi daily driven for 3 years 23psi when beating 25psi when overboosting.. Parted out car / turbo kit, compression tested engine still 205psi straight across Go figure? Still running in another car! |
