![]() Join Date: Jul 2012
ac runs pretty cold, but it makes a noise like its rocking back and forth as the blelt turns it pully. It also causes the engine to bogg slightly
![]() Join Date: May 2008
it could be the Auxiliary air control.. (mounted by the IAC).. it lets in a bit more air when the a/c kicks on.. does your idle raise
yes, idle does increase slightly. if the aac is the problem, would it only make noise when the air is actually running? And what exactly would indicate it as the cause?
