Since the pics aren't up at NICO anymore.. just wondering what exactly where to run a wire. Yellow w/ red stripe (TAM wire) to the Ignition coil positive or negative? Not sure if I should completely cut the TAM wire or splice the wire in. Any help would be appreciated.
Technical Articles: Converting Your SOHC Tach to Read DOHC Signal |
