i really need ur help i bought my 240 from this guy that dint have time to fix it so i took on the project well
first of all the fuel pump was bad so i replace that then a good buddy from Facebook came and help me but he could't find the problem so i look it up and i found this forum where it sed i had to jumper some wires near the fuse box but i bet y'all know witch so i connected that and my engine turns over but it dosnt' start any help or suggestion pleas help |
![]() Join Date: Jun 2003
Trader Rating: (129)
wow. you need to
A: consult a real mechanic B: brush up on your grammar and punctuation so we can actually understand what you are talking about C: just go jumper some wires and see if that works :smh: |
You shouldn't have to hotwire your fuel pump to get it to turn over, click HERE for a tutorial on how to do it.
Although a worthy modification, I don't think that will solve your starting issues. Are you sure the basics are covered? Fuel pump fuse? Edit: And how is this related to a 5 speed swap? haha |
Hello arty thanks for your Reply in a good way not like other People but I checked all fuses and relays
It was a automatic I did a 5 speed swap I fallowed this steps and videos on YouTube http://www.nicoclub.com/archives/aut...nual-swap.html And the fuel pump was bad so I changed it Today I worked on it and like I sed there's brown fuel in the spark plugs so I don't know what to do I'm just going to take the spark plugs out and turn the engine on so I can burn some fuel but I'm going to disconnect the fuel fuse first and thanks arty for the reply Sent from my iPhone using Tapatalk |
Yea it could be something simple like the neutral safety switch.. As for brown fuel you kinda lost me not unless your leaking oil from your valve cover and its mixing with the fuel.
Good luck! |
#10 | |
![]() Join Date: May 2012
