![]() Join Date: May 2012
So I am doing a S14 SR swap have harness ordered coming in tomorrow from Wiring specialties. I am running a L-Jetro Apexi Power FC. I have a S15 MAFS and on the stock harness I noticed the MAFS plug is diff than the S15 MAFS. I got the S15 MAFS piggy tail but I would HATE to do any cutting on this beautiful harness I am getting... (cutting on a 500$ harness is a sin). If I must cut into it will the S15 Pigtail match up to the S14 harness? I don't have a S14 MAFS. any help?
Man w/ CTSV & a Car Seat
You could have ask Yury to add the S15 MAF plug into the harness. He added a Z32 MAF plug on my harness so I got 3 different MAF plugs on my RB25 (Z32, S1 and S2 plugs).
damn a little too late for that. I know it comes with 3 plugs.
this is the harness i purchased. http://www.ebay.com/itm/190574087604...84.m1497.l2649 |
![]() Join Date: Aug 2011
Can you give us the part number on your S15 MAF ? I know S14 and S14/a MAFs are "identical" but only differ from the connector. I think they are labelled 69F00 (S14) and 69F01 (S14/a) . If your MAF has one of these wirings, then you can just get a standard S14 MAF.
You can probably email yury and ask to buy the plug from him, then just splice it in yourself. Not hard to do with a soldering iron, heat shrink and some wraps.
#6 | |
It is labeled 69F01 ill toss you a pm. |
