Need to know what size bolt this is.
Removing KA and i've hit a small snag with my wrench sizes which unfortunately stop at 19mm. Removing this from behind headers and don't know what size it is.
Sent from my HTC One using Tapatalk |
24mm x 1.5 thread pitch. Use vice grips to get it loose. You may even need to hit it with a propane torch for a minute to get it loosen up.
Goog luck Sent from my VS930 4G using Tapatalk |
![]() Join Date: Jul 2013
you mean a line wrench
95 S14 se RB25DET 348whp
![]() Join Date: Feb 2012
Trader Rating: (37)
Your best bet it's to use a pipe wrench because every other wrench will fail and leave you w/ busted knuckles. Good luck
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
![]() Join Date: Jun 2007
Pussies. I took mine off with a large crescent wrench and a touch of PB that I let soak for all of 5min :-)
Just kidding- All good ideas... but crescent wrench worked for me... I may have had to angle it so I could push it with my foot; but that was a LONG time ago. Good luck~ EDIT: Disregard- I thought that was the one on the downpipr section, not behind the exhaust mani. My bad. I say do what you can... If it strips, cut it off and plug it. Mike
