![]() Join Date: Aug 2009
![]() Feedback Score: 27 reviews
-- -- ---------------------------PM me for questions, info, or ask if I have something you need. +_+_+_+_+_+_TEXT ME PLEASE - 361-571-1026 DEAN_+_+_+_+_+_+_+_+ S14 OEM E-Brake Cables (GREAT Condition, 101,000 miles, no e-brake drifting) - $65 shipped S13 OEM E-Brake Cables (GOOD Condition, not stretched) - $60 shipped S13 KA24DE Engine Harness (Complete, Unmolested, great condition) - $110 shipped 300zx/S14 OEM Rear Sway Bar - $60 plus shipping S13 ABS Front Brake Calipers (Larger than Non-ABS Calipers, Loaded with pads and lines) - $80 shipped Cusco front upper strut bar - $110 shipped Zenki S14 Tail Lights Great Condition - $130 shipped S14 4-Lug OEM Hubs -Good Bearings -Peak Performance Extended Wheel Studs +15mm --These allow you to run a 15mm slip on spacer or so spacer at all and have much stronger wheel studs you don't have to worry about stripping or shearing. --$70 OBO shipped for the pair!!!! --(These studs alone cost $9.50 each) S13 Power Steering Rack Brackets with Bolts- $20 shipped S13 Steering Column U-Joint - $20 shipped S13 Headlight motor covers - $14 shipped S13 Power Window Amp - $20 shipped S13 Gauge Cluster Harness NON HUD - $25 shipped - S13 *MINT* Head Liner - $160 shipped - $40 picked up (Shipping is ALOT) - S13 Rear Seats - $20 Picked up - $150 shipped (Shipping is ALOT) - Zenki S14 Front Grille - $40 shipped - $20 picked up - Zenki S14 Custom naVan style front grille - $50 shipped - $20 picked up - S13/S14 5-Speed Transmission Cross Members - $40 ea shipped - $20 ea picked up -S14 OEM Suspension (great shape, 80,000 miles) - $40 -S14 KA24DE Engine Harness ECU Pigtail - $20 Shipped -S14 ABS Brake Master Cylinder - $30 shipped $20 picked up -Single Gauge Pod - $15 shipped $10 picked up - S14 Zenki white front bumper with some damage - come get it free - Mint s13 hatch privacy cover - $70 shipped $40 picked up - S14 center console - $55 shipped $20 picked up - S14 climate control - $35 shipped $20 picked up - S13 side mirrors - $30 shipped each $20 picked up each - S13 hatch tail lights (2 full sets) - $60 ea set shipped $40 each set picked up - S13 front crossmember - $100 picked up - s13 center console - $40 shipped $20 picked up - S13 drivers side power window control trim - s13 mint radiator hold down brackets - $40 shipped - S13 window glass - $60 each shipped $20 each picked up - KA24DE Intake Air Temp Sensors - $20 shipped - KA24DE Fuel Rail No injectors - $40 shipped - S13 Engine Bay Fuse Box Bracket - $25 shipped - $20 Picked Up - S14 Power Steering Reservoir & Lines - $40 shipped - $20 Picked Up - S13/180sx Headlight Brackets - $40 shipped - $20 Picked Up - S13 & S14 Door Handle Trim - $10 Each shipped - $5 each picked up - KA24DE & KA24E Water Pump Pullies - $15 ea shipped - $5 ea picked up - KA24DE Starter - $60 shipped - $20 picked up - KA24DE Alternator - $60 Shipped - $40 picked up - S13/S14 Brake Booster - $50 shipped - $40 picked up - S13 Hatch Trunk Trim - $50 shipped - $20 picked up - S13 Hatch B-Pillar Exterior Trim - $40 shipped - $20 picked up - S13 Blinkers - $30 Per pair shipped - $20 per pair picked up - DIN Pockets - $10 ea shipped - $5 ea picked up - KA24DE Crankshaft (No damage, no bullshit) - $80 Picked up ALOT shipped - S13 KA24DE Harness Pigtails - S13 KA24E Harness Pigtails - S14 Harness Pigtails - S13 Chassis Pigtails Last edited by drifter92; 07-25-2013 at 06:52 PM.. |
![]() Join Date: Jul 2013
hey dean i need the front turn signal light socket with a few inches of wire on it. Also need one for the side corner light thats next to the headlight (S14)
95 S14 se RB25DET 348whp
