front main seal leak, searched
I searched this forum and others but my question wasn't covered. I replaced my front main seal recently, bought from a Nissan dealership, and now the leak is worse. I carefully pulled the old one out and tapped the new one in, took me about 15 mins to tap it in just to be safe. I also bought and installed a new key. I was able to find that some people recommend greasing the seal before installation, will not doing this make it leak worse? Somebody recommended looking into a 300zx seal as it may be thicker; I wasn't able to find anything on that. I go through 3 quarts a week as this is my daily so the leak is pretty bad and yes I check it daily. Any advice would be appreciated.
#2 | |
![]() Join Date: May 2009
Bet you need a new harmonic balancer. A little grove wears into the balancer where the seal rides.
Some times, like Zero said, the seal wears a groove into the crank pulley, where the seal rides. I would pull the harmonic balancer off and look at the snout that slides into the main seal. If there are some scratches and or a small groove you need to purchase a new harmonic balancer.
My SR20VET |
![]() Join Date: Jun 2007
Not to insult anyone's intelligence... but for OP's SA, the seals are one-way-only... If installed backwards, it will force oil out, rather than keep it in. Not saying this is the case, but ya never know.
Usually the seal sits flush with the front cover from the factory. If there is a groove on your crank pulley you can always mount the seal further in so it's not stuck in that groove. A little engine oil around the seal helps the thing slide in. Also make sure it's not crooked or it will leak again fairly quick.
#6 | |
