Need quick Help with Greddy Intake mani
last night i was working on my car and my friend took out my old manifold and then left and i never got to see how things were set up before. i got hoses giong everywhere and i am not to sure where and how they hook up to the greddy intake. if someone could just write up a quick install for my i would be so grateful. also i need to know what i must do to the fuel rail to make it fit too..... so any help or pictures will help alot guys
thanks alot --steve-- |
Man w/ CTSV & a Car Seat
K....2 lines in the back. Ones for the valve cover, the other ones the line for the brake booster solenoid thats on top of your fire way. Underneat, you got 4 total water lines. One pair connects to your air bypass box and the other pair connects to your throttlebody.
For your fuel rail...iirc, you have your hose from the filter, connects to a metal line *which is your problem rite now*, loops under the manifold and connects to another piece of hose thats connected to your main fuel rail. What i did is i just completely got rid of the metal line between the main rail and the filter. |
