Well when the car isn't running i have a good stiff pedal
But when i start the car i have NO brakes and have to go to the floor I know on the older cars there was a vac line that you hooked into the back of the carb Is there something like that for my 92 s13 |
![]() Join Date: Jan 2006
yea
u gotta reset your float level and go with smaller jets and bigger primary and secondary metering rods. lal seriously bad brake booster or bleed brakes i dunno fuck.
ho ha ho chi chi |
![]() Join Date: Jul 2007
i think most cars will have a stiff pedal when the engine isn't running.
but check the vac line that leads to your brake booster for leaks and what not. check for leaking brake fluid around all your calipers check your hardlines do you have abs?
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving |
Okay well it must be the line somewhere because i was out there for an hour bleeding my breaks
So how do you tell if it's ABS or not I haven't seen markings on the car that say abs sorry i'ma to 240's |
![]() Join Date: May 2007
you aren't bleeding your breaks... you were bleeding your brakes.
<------ Grumpy Old Asshole MY REVIEW THREAD: Ltdnismoracer4=DOOK #/f/showthread.p...ltdnismoracer4 |
