2007-2009 Toyota Camry engine problem
If anyone here has or knows someone with a late model Toyota Camry (2007-2009) make sure to check the engine oil level regularly. I've noticed that my Camry has been burning up oil, but didn't see oil leaks or drippings anywhere. Turns out it's caused by defective piston rings. This is a very common problem in late model Camrys. Toyota won't cover the cost of the repairs due to the fact that my car is outside the 5year/60,000 mile warranty.
Toyota has extended warranty coverage for oil consumption.
http://www.toyoheadquarters.com/thre...e-lsc-ze7.362/ If your engine consumes enough (1qt in 1200mi) they will rebuild the engine (I assume for free for primary coverage). I bet this is just a bot.... |
![]() Join Date: Jan 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
So you joined a completely different forum to post your troubles?
If that is a bot holy fuck that's scary And to clarify I mean a bot that randomly generates posts, not just a bot that is programmed to post a certain message written by a human. |
