![]() Join Date: Feb 2010
motor is a sr20det s13 blactop on s13 hatch, stock everything. i parked the car about 2 weeks since i was selling some old parts and getting new ones. before i parked the car it ran great. good idle, good mpg. i finally turned on the car last night. it turned on fine but a few minutes later it started throwning black smoke running super rich and shaking. i unplugged the maf and the BLACK smoke and shaking WAS gone. since i dont have an extra sr20 maf i did some rewiring and installed a sohc maf. Installed the sohc maf and same shit, throws smokes when plugged, stops when unplugged. PLEASEEEEEEEEEEEEEEEEEEEEEEEEEEE HHHHELLLLLPPPP. ANY INPUT WOULD BE GOOD.....
without being able to source a known good maf its hard to say.
have any friends / locals that could drive over and lone u theirs for the 5mins itd take to check? when its plugged in and all,. where do your rpms drop?
cONtRol FReAkS |
![]() Feedback Score: 29 reviews
I have a maf, 80 shipped 4 days to your door.
905 962 7498 [email protected] Send me a text when your ready, I can ship out TODAY |
Ima check the intercoller piping, also a mechanic said my air intake could have leak throwing off the readings. I hope I can get one of my friends to let me borrow his for a lil while. And to guy trynna sell me one, thanks and ill def let you know if I need it. Thanks a lot for the input everyone.
#13 |
I forgot to mentioned that over the time I didn't drive the car it rained a lot and my windshield isn't sealed right. I thought about moisture too. Ima go home and open up the ecu to make sure is all dried as well. Would a bit of moisture ruin the ecu or can I fix it just by drying it up???? I can't wait to get outta work and do some test on the car
Fml. I tried my friends maf (same motor). And the problem was still there. Decided to check out the ecu for any type of moisture and there it was! On one of the corners of the ecu there was some kinda dried up moisture where water may have landed. On the ecu connector and a small part on the pin out. I tried cleaning it up w an 'electrical cleaner' spray can. It looked good after the cleaning, I plugged it back in and same shit. FMFL. My ecu number is J4, I asked my friend to try out his ecu E5. The car would barely stay on. So now I can't tell if the ecu is bad or if maybe the water created a bad connection and burned out the wire that reads the maf since everything works fine unless the maf is plugged. I know this is long but I really need some help. A used J4 ecu is 250 bucks
#16 |
I talked to one of guys at enthalphy (really nice ppl btw) he said to check voltage on the maf and on the ecu. I'm not experienced at all when it comes to wiring so I'm a bit confused. He said the 'black and white ' wire goin to the maf should read 12v. But what doesn't? Does it mean that the ecu is bad? Or maybe the ground for the maf got messed up?? I'm fucking clueless.
#17 |
Maf has 3 wires
12v ground ecu control wire... TRY JDM OF MIAMI FOR ECU LEGIT SELLER AND HAS EBAY STORE
シチサn w/ka20det:in progressシチサnw/sr20det:stolen |
#18 |
![]() Join Date: Apr 2010
Make sure your maf plug is not plugged in backwards...
also.. if there WAS a problem and you FIXED it, you may want to pull your plugs and make sure they're not still SOILED, and that's what's currently causing the problems. Good luck with the fix |
#20 |
Theres a j4 on zilvia right now for $50 or so. Though I haven't read the actual fs thread. An e5 wont work on your car if you need a j4. I think the mafs wiring are the same, have him use your mafs.
#23 |
I checked the plugs today and they were hella black. That explains why my friends maf didn't work. I put some old spark plugs and the car actually stayed on for a lil while without smoking. I tried revving in and it started smoking. I'm gonna buy new plug and try my friend maf again. Wish me luck. I got quote 300 from wiring specialist for a new harness to fit redtop ecus, just in case my ecu is fried. Gonna take off bumber and get a compressor to do a boost leak test as well. Damn I miss my car. I had just gotten stance coilovers and new wheels and this shit happened. Bummer from hell.
#24 |
Update: i got new spark plugs andrewired the single cam maf. Turned on car and let it idle for a while. No smoke til now. As soon as i revved it the black smoke started coming out again. I turned off the car right away cuz i didnt wann messed up my spark plugs again. So Pparently itsnot the maf
help. |
#25 |
got the same problem wit my s14 sr20, i still havent found out wat it was and i put in new plugs, wrking maf, new tps, way better BOV, checked for leaks and still the same shit, i just got a wrking ecu in yesterday so im gonna b throwing that in and hopfully it wrks
#27 |
update brotha, i put in the ecu i just got and the car is idling WAY better, no blck smoke and doesnt shake anymore and no breaks or back firing when reving it, so i would say get a new ecu... oh and also i replaced the IACV
#28 |
Alright. Yeah my iacv had calcium builup when i got the motor but i got it pretty cleaned up. I guess its time for a new ecu. I will update soon. Where did you get a new iacv?
#30 |
Update. Nobody around here had a j4 ecu so i ended up buying a brand new harness from wiring specialist ( yuri is great btw), and getting a redtop ecu from a friend. I installed evevything and turned on the car. It idled perfect for a lil whie and then it started again the damn black smoke again. I turned off the car because i didnt wanna ruin my brand new spark plugs (3rd ones). i also put a fuel gauge and the pressure its a 38 at idle. Wtf is going on? Im about to give up. When i took off one of the plugs i could see a bit of black smokecoming out still. What could it be? I pull the codes from the ecu and it gave me 55. Help please. I need my car really bad
