#121 |
![]() Join Date: Feb 2005
looks like they only make 30mm fenders, from that company
Car and truck body kits & parts for mx3, s10, SUV, civic, neon, focus, etc. |
#122 |
Recently hit a curb in my S13....bent my LCA to hell...replaced the LCA...and the hub was still tilted in positive camber....messed around with the UCA and put the car back on the ground...and the tire still leans out just a bit with some positive camber...did i possibly bend something else? UCA? Spindle? any suggestions? i was thinking about getting an alignment...but i dont want to spend money when something else could be bent...
#125 | |
![]() Join Date: Jul 2005
bdubnyc - check your actual shock tower, if you bent the LCA that bad I wouldn't be surprised if your whole front frame rail was tweaked.
![]() Instagram - SJKnoop |
#126 | |
![]() PS: Oh forgot to mention...the driver side is fine and the negative camber is still fine on the driver side ever since i lowered the car...its just the passenger side where i hit the curb that still has the slight positive camber from hitting the curb. |
#127 |
My bad, I didn't read your post right then.
Did you check out all of your arms? I'd check the camber arm itself, and check the areas the arms bolt to on the subframe. Compare to your side that didn't hit.
#128 | |
check for any major differences, at the very minimum you can source all new stock arms as they aren't worth shit |
#129 |
Yea ive compared all the arms to the driver side and they all look fine...i plan on swapping out the upper control arm with another stock one sometime soon and see if that makes any difference.
#132 |
#134 | |
![]() Join Date: Aug 2007
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
Not saying this will fix it but hey give it a try ![]()
#135 |
Trader Rating: (36)
Im not sure if this qualifies but it is a question.... Is there anyone on here from Socal that specialize in electrical? Im having an electrical issue (short) on my S13 and looking for someone that can help a brotha out.
#139 | |
i believe he knows a good deal about electrical and wiring |
#140 |
I have a Vertex shift knob with nissan thread pitch, but I know have a toyota. Can I buy just a regular heli coil and take the old on out so it will work with my thread pitch?
#145 |
ok guys so i took the intake mani of my redtop and in the lower portion(connnected to TB) i found oil. like a decent amount. is this bad/normal? thanks
@UpshiftEngineering |
#146 |
![]() Join Date: May 2004
Trader Rating: (26)
my friend wondered the same thing and grounded that tab. his car started fine but was running weird/abnormal. he took it off and his motor was running like it should. i also have a ka24e and that tab isn't hooked up to anything.
#147 |
hey guys i just need a quick advice on how i should install the roof wing on my coupe. what kinda tape should i use or do i have to bolt it on or is there another method of installing it or any helpful advice will do
thanks guys ![]() |
#148 |
Bandwagon.
3m double sided tape.
#149 |
my question
I have an hks top feed fuel rail im looking for 660cc top feed injectors but all of which i have found have low impedance and sr20's use high impedance, how could i make these work? i read about dsm resistor from an eclipse but not sure about this. |
#150 | |
(ノಠ益ಠ)ノ彡
![]() Join Date: Apr 2008
thank you, makes perfect sense that the bearing will wear away from the added leverage. |
| 180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
