sr20det idle dipping, wierd..
hey guys, the car has h-dev stage 1, apexi filter, turbo back 3 inch exhause, recirc dumpvalve, new vakuumhoses all over, tps set to 0.45v ( is that correct? read it in a guide ) timing set correctly, didnt find any boostleaks, tried different afm, changed injectors to known working ones ( thinking one could be clogged or something) checked alternator, measuered a healthy 14,6v so any ideas would be lovely.
![]() And yeah i know my exhaust is leaking, ( around the cat.. ) IMG 0531 - YouTube |
![]() Join Date: Sep 2005
check ecu for codes, it appears to be a mafs wiring issue, only because you swapped mafs already.
so to clarify, it could be the mafs connector, wiring or the ecu.
