#3902 |
![]() Join Date: Oct 2006
You have a lathe.... Make a radius tool....
I can barely machine at all and I e manage to make one using a boring head... If only I still worked at that Place ![]() Hardly a need to buy one. |
#3903 | |
![]() Join Date: Apr 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
#3904 |
![]() Join Date: Oct 2009
i dont have a ton of experience with different lathe tools so i wasnt sure how easy it would be to make one. i'm definitely the type to make (or try to make) something before i buy an already made piece.
thanks for the link. i lol'd at "everywhere i look needs a ball" |
#3905 |
The start of my first exhaust. Having some issues with porosity in the welds, which I've been told is either not enough gas flow from the regulator, or not holding the nozzle close enough to the material and therefore loosing gas flow.
Flange and turn down were salvaged from an old exhaust I had in the garage. I feel like the tacks on the spun cat came out correctly, but the lumpyness of the turn down makes me realize how many things I'd forgotten since I last did any practicing. I'm also open to any comments people might have on how to improve what I'm doing here.
'95 240 | @SleepySteve72 |
#3907 |
![]() Join Date: Sep 2007
used my collector fixture to make this collector...
I miss-rotated the last cut on the runner in haste to get back to wiring my turbo miata... Start of wiring night: End of wiring night:
www.facebook.com/HellaFab |
#3909 |
It does make me feel slightly better about my own exhaust welding.
'95 240 | @SleepySteve72 Last edited by Sleepy_Steve; 07-20-2011 at 01:32 PM.. |
#3910 | |
Finished product:
#3916 |
Where did you find the plenum to build this manifold?
Volume?
#3919 | |
I had a ($285) 1/3hp, 4 1/2'' x 6'' band saw with a 1/2'' blade and no coolant system. And made by the same company. Tried cutting 1.5 sch10 SS pipe... Massive fail... I said "fuck this shit. I'll just spend the money I don't have".. So happy I did. This one cut that same pipe like it was aluminum... I also cut some 2'' chrome rod. Took a while but the saw didn't even hiccup. DO NOT cheap out on a band saw... It just won't cut it in the end... Literally I'd look for nothing less than a 1hp motor. Coolant system is a must. People can say otherwise but if you take your fab work serious at all. It's a must. |
#3920 |
![]() Join Date: Sep 2008
Twin charge it !!!
If you do end up puting that second intake on there some how you have to twin charge it.
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
#3921 |
vband weld on sanitary 304ss
#3924 |
![]() Join Date: Oct 2008
any one have good luck welding cast with a mig? i welded a v-band flange to the exh housing of the 35r and its been fine all year but i am looking into modifying some s13 front knuckles and im a little worried since this part is going to take more of a beating for sure. i've got a good welder, lincoln xt255 just wondering if there was any tips.
#3927 |
![]() Join Date: Feb 2009
My tool buying is finally complete! Ordering my tubing this week. So much money spent since January...
![]() From left to right: Pro-Tools Model 105 Bender with 1.75" 6" CLR bending die Lincoln Electric Precision Tig 225 with 125CF argon tank Angle Finder Morse Hole Saw Set Pipemaster 1.75" pipe fitting tool Rigid 14" Chop Saw Shorty back cap for my WP-17 tig torch JD2 Notchmaster + hole saw adapter Cutting oil
My Website | Unfriendly Garage | Endurance Motorsports | FitMyWheels - Fitment Calculator |
#3929 |
I think it was about $805 (with die) with a pirate4x4 discount code. TMR Customs, just find their forum on pirate4x4.com
#3930 | |
Since march I've bought: JD2 Model 4 bender with 6 die sets (last march though) Everlast 250ex tig Craftex (identical to Grizzley) 7x12 bandsaw Two 8" bench grinders Belt sander Baileigh TN250 tube notcher (on the way) And a shit load of materials to build: Tube roller Dimple dies Dies for English wheel Not been a cheap year for tools! |
