![]() Join Date: Feb 2010
bc stage 2 cams
hey guy, I got a 19' 240sx with a sr20 red top and i was thinking about getting some cams in the future. I was looking at the BC stage 2 cams and had a question that i couldnt find the awnsers to by looking up reviews and stuff.
they are 264 cams with 12.06mm of lift and it says they i dont need to upgrade my valvetrain and i was wondering if anyone knew if that is ture or not? and if it is are the direct drop in or not? link: Brian Crower BC0201 Camshafts Stage 2 Street Strip 264/264 S13 SR20DET |
![]() Join Date: Dec 2004
Trader Rating: (58)
BC says to use springs and retainers, then yes they are needed. Becomes expensive doesn't it? And to think it will still require cam gears as they are junk cams, and will still make less power than Jim Wolf S3's or HKS 264 Step2
Save the frustration, buy a set of Jim Wolf S3's (no need to upgrade springs or retainers) and make more power. Much better cam, install as OEM and kick ass.
so the jw s3 260 cams are direct drop in?
Jim Wolf S3 Cams 11.2 Lift 260 - SR20DET [ ASER1-990S3 ] - Enjuku Racing - Performance Parts and High Quality Fabrication |
