KA24DE intermentient sputter on cylinders 2 and 3
Hey guys, new to the site and I have a problem.. My injectors act up at random times (or what seems to be the injector). I have replaced the o-rings and the injectors.also the fuel filter. I would like to think if the FPR was bad it would be on all cylinders. I've ran noid lights on the injector plugs and they're working properly which tells me the wiring is good. I'm not sure where else to look. The skip will come and go, sometimes when you crank it up, other times when your changing gears, sometimes it will go away when you cut the ignition off, and other times it won't? If I had to guess it's getting too much fuel. I'm really lost and any ideas would be greatly appreciated.
