Transmission Options
Hello
I'm looking to replace the manual transmission in an s13 hatch with something more automated. As much as I'd love to keep the stick, my situation requires something without a driver operated clutch. I've been looking at dct settups (dual clutch transmission), but recently heard about something really cool. Apparently you can swap a manual shift valve body onto an automatic transmission to make it shift only when told by the driver, however since it still has a torque converter there is no clutch to worry about. Does anyone have experience with this or know if a dct swap would even be possible? Many thanks to you all! Sent from my XT1526 using Tapatalk |
![]() Join Date: Mar 2009
There used to exist a paddle shift kit specifically for automatic 240's. Paired with a beefed up trans it could be a good option potentially. Unfortunately a lot of pictures in this thread don't work, but it's a start. Could try contacting some of the companies mentioned. http://www.nicoclub.com/archives/240...onversion.html
check out my thread from ka-t.org http://www.ka-t.org/viewtopic.php?f=40&t=62525
my s13 testbed uses a stock 240 auto trans RE4R01A with a transgo shift kit and a sequential shifter and circuit i built to control shift solenoids. AEM ems handles line pressure,lockup, overrun solenoids. There are links to videos to explain and some pics. I havent broken any hardparts in the trans @404rwhp that i'm at right now. I expect trans to let loose at about 600rwhp. PCS or powertrain control solutions makes a trans ecu that will control most electronically shifted transmissions out there if you choose something other than nissan. AND they have paddle shifters options. The whole kit I priced out at like $2000. Do it. Its fucking awesome to drive just check out my vids. Theres an in car [email protected] outside view, explanation of sequential shifter and more in car on the street at 10psi~~240rwhp. https://www.youtube.com/channel/UCQL...yx5tm70uj4htpQ did some looking this morning and here's all the products i'd recommend. trans controller https://www.powertraincontrolsolutio...ller/TCM-2000/ RE4R01A harness (if you stick with bolt on capable trans) https://www.powertraincontrolsolutio...ller/TCM-4124/ Paddle shifter kit https://www.powertraincontrolsolutio...addle_Shifter/ Trans Fluid http://www.bmracing.com/products/802...ty-of-12-only/ Valve body shift kit http://www.transgo.com/products.php?...dcountview=Yes Trans cooler any will do If you need more technical information, I can help or PCS can help get you a badass setup. |
#6 | |
![]() Join Date: Aug 2011
Quite the bargain. |
Gotta pay to play the way you want.
There isnt any machining needed, its the stock auto that bolts up everywhere. Now if he wants to go outside of the RE4R01A, then yes all the costs of swapping a trans must be factored. |
From what i read, the OP seems to have a problem operating the clutch.
I seriously can't see the point of shelling 2K$ and quite some work to add paddle shifts. It is a damn 240sx, not a lamborghini. The whole car is worth that money, at best. @OP before you start buying parts here and there, just drive an S13 with an autobox. It does the job correctly. If you are ready to shell out major money for a trans upgrade that does not use a clutch, you may as well get another car as you will *NEVER* see that money back. For the kind of money required,you can get something newer, better and better looking than a 240. |
#9 | |
If all you need is lower clutch pedal effort, i found out the spec stage 3 and the XTD stage 3 clutches are butter smooth. Although i don't recommend the XTD otherwise, because it wears out VERY FAST (did less than 10k miles before it started slipping)
nitrous is turning on and off
converter clutch is locking and unlocking several things 1. a friend and i were trying to get kicked off the track and run 10's in my shitbox street car when it was difficult 15 years ago in my race car. (which was an S13 coupe) 2. That same friend talked me into shooting the 2nd stage up to a certain rpm 3. The tune up targets 22psi and had some features like anything over 24psi unlocks the converter. This was a random "i'll never hit more than 24 so as i'm pressing the up key i'll just stop here" 4. The tuneup had nitrous turning off i think above 5700 i cant remember. 5. Anytime you shoot nitrous boost is going to come up a little. Well it came up past that 24psi unlock feature and unlocked the converter. 6. Anytime you unlock the converter, you get the normal 10% SLIP a fluid coupling device affords you. So rpm flares up a good 500 or so rpm. 7. When that happens it goes above the nitrous turn off rpm and turns off the nitrous 8. nitrous turns off boost comes down, converter locks back up 9. rpm is back below 5700 or so so nitrous turns back on and the process repeats itself 2-3 times per gear. NOT the way i intended it to be and thats why its called tuning. This is also the reason it delaminated the lock up clutch in the converter. When i get the trans back together i'll smooth out that transition and the car will do 10.50's and take out that gtr next time |
