help with 96 240sx codes
I need some help with a couple of codes my car is throwing. Any help appreciated I know the o2 sensors n the rest how can I fix them
P0130 P0505 P0325 0135 0446 1445 1105 |
![]() Join Date: Feb 2004
P0130 is O2 malfunction. - Change your o2 sensor
P0505 - is your Idle Air Control Valve - Clean your IACV also check for broken or cracked vacuum lines. P0325 - Knock sensor -Change sensor (kinda pita to do, but it can be down with patience and correct tools) P0135 - O2 heater bank malfunction - Change your O2 sensor P0446- Evap cansiter - check all the lines make sure no cracks or leaks etc P1445- EVAP Canister Purge Volume Control Valve - Could be stuck open ties in with the other evap codes P1104- MAP sensor (little box on top of the intake manifold with 3 vacuum lines coming out of it) - Check it maybe need to be replaced, it ties in with your EVAP and could be the issue with the rest of your evap codes I would first change out your O2 sensor, clean out the IACV first. Clear the codes, then see if that fixes anything. After that go from there. |
![]() Join Date: Jul 2013
couple of codes...lol thats 7 codes!
is this a car you just put the engine in and this happened or do you let the codes build up over the last 10 years lol
95 S14 se RB25DET 348whp
