![]() Join Date: May 2012
Sr20det doesn't go past 3,500 rpm
Hey everyone I just rebuilt my sr it starts up and everything but when I try and rev it up it doesn't go past 3500 rpm it just pops and like the engine does out but doesn't turn off... I pulled the cas off and set that but when I did that the timing links didn't match up to the marks on the cam anymore... Would I have to pull it all apart again and set everything over? I really hope I don't have to because I would haw to pull the engine out to get to it... Please if anyone has run into this problem let me know ASAP! Thanks in advance!
![]() Join Date: Jul 2007
you just have to put it at top dead center, line the little pin sticking off the front cover up with the 2nd mark from the left on the crank pulley and then set the cas to the dot closest to the assembly and restab it and the not going over 3500 sounds like a MAF sensor issue
you don't need to take the front cover off you misread what i said, there is a little pin sticking off the front of the front cover right over the crank pulley, u just rotate the crank until the pin lines up with the correct mark on the crank pulley it self, not wrenching required
if you installed everything properly, when you roll it over to top dead center everything should be lined up, if not then you fucked up when you assembled it
#19 |
should be 12v going to it. idk which maf u have but one wire should have 12v going to it.
with my old coupe i had a rb20 in it and the 12v wire had resistance somewhere along it and only gave 8v to maf so i had to rewire that wire from the ecu to maf |
#20 |
then put it at TDC, pull the cam gears and set the chain on them properly and put them back on the cams, problem solved, aslong as you make sure it stays at TDC the whole time
#22 |
Well I just pulled off the maf when it was running and it idles higher and a Lil smoother when I plugged it back in the car dropped in idle and was a Lil bit rougher them when it wasn't plugged in
#26 |
AFC #1
![]() Join Date: Oct 2003
There are 3 lines on the maf. Power, Ground and Sensor.
You are saying you have 12v, 0v, 10.46v?
