![]() Join Date: Sep 2005
The cooling system is supposed to build pressure, the hoses will get hard. If the pressure gets to high the cap is supposed to vent.
If you believe the headgasket is the cause, they have test for that. If you believe the water pump is failing, there should be proof. Bleeding the system isn't going to remedy the swelling issue. All you really have to do is bleed out 80-90% of the air, basically putting fluid behind the thermostat the remaining air is bled through the cap. Sent from my Highly Tuned Note4!!!
