S13 throttle body seals
Tonight I decided to do a boost leak on my car and found a good leak coming from the TPS... I took it apart and the o rings in there were trashed.. I've searched for a while looking for these with no luck. I was wondering If anyone can tell me a solution with my problem and maybe where I can find these rubber seals... thanks in advanced.
IG: @ozc2jz |
![]() Join Date: Mar 2007
Trader Rating: (31)
Wow...Thats interesting.
My car Acts like it has a Vac leak and I would have never got to that ppint because I would have Blocked off the Pipe before Entering the Throttle. I'm in for this. I can only think a New TB would fix this? Edit: did you smoke test It??
z-tERty-2 |
#6 | |
I do have a DE throttle body sitting in my garage with a TPS on it... if you want I'll check the o ring.. I can send it to you for postage (worthless to me.. I have a TB on my car already) Last edited by JBrock78; 06-17-2012 at 01:04 PM.. |
