Old 11-16-2010, 07:08 PM   #1
s13superstar
s13superstar's Avatar
s13superstar is an unknown quantity at this point
Smile how to remove s13 diff.
hey guys the title pretty much sums it up but i can't find any links or tut's to help me. can you guys help me out or give me tips?
1994 240sx SE- SOLD
1983 Cressida - Factory 5spd.
s13superstar is offline   Reply With Quote
Old 11-16-2010, 07:15 PM   #2
adrians_s13
adrians_s13's Avatar
its pretty much straight forward, loosen up all the bolts that connect the diff to the driveshaft and the axles. Support the diff with a floor jack, then you got the 2 big bolts up front (where the bushings are) and like 4 in the back, then after all the bolts are off, lower the diff. I'd recommend draining it first before removing so its not soo heavy...
@adrianfromthecastle
adrians_s13 is offline   Reply With Quote
Old 11-16-2010, 07:15 PM   #3
Sileighty_85
Sileighty_85's Avatar
^^Damn beat me too it lol
Unbolt Axles and drive shaft and sperate from Axle flange
remove the 4 nuts from rear cover
loosen the 2 front bolts
Support
remove Diff
Im sure if you go look at it Id hope you could figure it out.
also im sure the FSM will tell you how to do it as well
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-16-2010, 07:54 PM   #4
JDGrimReaper666
JDGrimReaper666's Avatar
JDGrimReaper666 is an unknown quantity at this point
DIY: Weld a Differential (w/ removal guide also) - Nissan 240SX Forums
this might help....
"Show no compassion, like having a straight face orgasm"
JDGrimReaper666 is offline   Reply With Quote
Old 11-17-2010, 03:28 PM   #5
s13superstar
thanks for the help guys, will try it out tomm.
1994 240sx SE- SOLD
