![]() Join Date: Jan 2003
gt2871 turbo
I have seen two threads which include this turbo, but I've not seen much real info about it. I hear these 2 things
it costs 1300ish from atpturbo, it does 400hp per atpturbo.com's website. It is a dual ball bearing t28...with the compressor/or exhaust side 71mm correct me i'm probably wrong. Its suposedly around the same spool time as the gt28rs aka disco potato, but closer to the power of a hks gt2835... again correct me if i'm wrong. I would like to know what the real spool is like, and when the effeciency will drop off. Also, pricing and the real max hp etc. Also i'll assume it drops in very similarly to the 28rs, 2835 in that it will fit ur typical t25 flange, yet the oil/coolant lines will need to be modified etc. also internallly or externally wastgated? |
One other thing.... If im not mistaken, the gt28rs drops right in with modified coolant/oil lines, will it clear the LHD steering columun etc...manifold? Also if i put say a greddy/hks/project nissan turbo elbo, will it fit fine ?
email from [email protected]
Steven, It's the big brother of the GT28RS (disco potato) and with a larger (71mm) compressor wheel this turbo can flow up to 400 HP. On a 1.8L to 2.0L, full boost is about 3500 rpm with a .86 A/R exhaust housing and 3000 rpm with a .64 A/R exhaust housing. Cost is $975. Cheers, ATP |
don't mean to hijack this thread but how does this turbo compare to the gt25r .86a/r? Does it bolt up to the stock manifold and also will it bolt up to a greddy o2 housing?
again correct me if im wrong, but off the top of my head i remember two gt25r a/r's one .86 and .63 the .86 if i remember made like 450 the other oen made 3xxhp don't remember... and yes it will bolt up off the top of my head but i posed that question just to double check. |
![]() Join Date: Jun 2003
$975 sounds like a misprint...I bought mine from there for $1311 gt2871r...maybe the "r" denotes a different turbo...They aren't going to sell a larger turbo in the same line for less money (gt28rs vs. gt2871r) Oh, and it's internally gated.
Ryan
#8 | |
Ryan
yeah i would really to see dyno results. When i do get my sr powered 240, i am going to be deciding between the gt25r .86a/r and the gt2871r. I wonder which would make more power. I have seen many dynos with the gt25 with cams, obx manifold and greddy intake mani. I want to see dynos from the gt2871r.
#10 | |
is the gt2871r internal or external wastegate? lets us know how it performs. |
#12 | |
![]() Join Date: Feb 2004
Intersted in this 2871 dyno also. And $975? that does seem odd, as the GT25R is about $1200. the GT25R comes in .86 or .64 AR like the turbo you are speaking of.
![]() Join Date: Dec 2003
the 2871 is showing to be a nice turbo upgrade for the SR. We have gotten out quite a few. It does indeed have the 71mm compressor with the larger GT28 Turbine assembly. We have seen the .64 A/R exhaust housing be the most popular.
The spool is very fast and the custom 3" T04E compressor cover prevents any real surge issues. If you have any direct questions about them please feel free to contact us.
![]() Join Date: Sep 2002
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
wow, you said you searched? there is tons of info on this turbo, and especially on FA and Nico... a .64 a/r will give you close to 360+rwhp
89 240 SR powered... ummm i promise its stock
Like TheSparo said, there are tons of dynos on the gt2871 on FA. They've done a load of comparisons between the different A/R sizes that it comes with as well as comparisons between it and the disco potato, all with dynos to prove it. You guys have to use FA more. That is the most valuable library of technichal info about s-chassis's in my opinion. Use it to your advantage.
#17 |
![]() Join Date: Nov 2002
I got my turbo from The Speed Factor much cheaper than what ATP sells it for, you guys should call them up (probably ask for Martin) and see what he can do for you. I love my GT2871R in .64 a/r on my KA. Yes, I said it, on my KA. This turbo is sooo smooth in power delivery and it doesnt even fall off on the KA, which means it definitely shouldnt' fall off on the SR up top. I hit full boost by ~3300 rpms and this turbo definitely likes higher boost levels. I am at about 9 psi right now until I change over to a daughterboard, then back up to 14 psi where I was before for a short time. I highly recommend this turbo to anyone looking for a direct bolt on to the SR manifold. I've heard you can just play with your stock lines and it will work out, but I'm guessing it's much easier to run the Taka Motorsports lines... or even talk to Martin at The Speed Factor to see if they can hook you up with a coolant/oil line kit for your application. (I of course ran custom lines on my KA).
![]() Join Date: Jul 2003
i also got this turbo in my redtop. almost done with it just need to get the damn maf in. I ill post info on it at soon as i get it done. i will also post some dyno charts if any one if intrested.
#19 |
![]() Join Date: Mar 2003
just as a note i can get gt2871r for right at 1000 through the shop that did my swap but prices are getting ready to go up soon across the board on all garret turbos except i think the disco potato iirc.
CA18DET t25, 440CC injectors, Greddy FMIC, Greddy Hot Pipe, Greddy Type RS Bov ,Greddy Turbo Outlet, Trust DP, Motoria 3" Catback , XS Tubular Manifold, Nismo AFPR ,Nismo Engine and Transmission Mounts ,Apex'i SAFC 2 Walbro 255lph, LSD, SPL Subframe Collars, Tein S Tech Springs, Tein Tie Rods, Upper Front and Rear Strut Tower Braces. Black 180sx wheels. |
#20 | |
