Title pretty much sums it all I took a video so I can be as detailed as possible here's the YouTube link
S14 240sc squealing happens when the car moves or when I move the steering wheel - YouTube Basically the front started squealing 2 months ago then about 2-3 weeks ago the back started, it seems to be getting worse and worse, I have a feeling this is a known issue I know it's not my suspension cause my other s14 does it too and it has brand new tien coils and fl is pretty flat and I don't abuse it so there's no way they're blown Could it have anything to do with working in an environment where dust is e wry where? Like dirt roads etc cause both cars started about a month of driving to and from work and if so anyone know where I can start? |
Sounds like the brake disc dust shield is rubbing the disc, happened to my maxima, when I turned one way it go worse the other way it went away. Pull off the wheel, push/bend the shield away from the disc, you only need a few mm clearance
4 SALE intercooler mafs valvecover rep fn01rc http://tinyurl.com/jmaxzilvia |
Put some grease on the front shocks like this
It doesn't have to be mobile one, But any Type of grease should takes car of it. http://www.autozone.com/autozone/acc...equestid=80375 |
