![]() Join Date: Feb 2010
17in work vs kf wheel spec chart?
Hi guys, I just recently acquired some vs kfs and are having them redone at vr wheel. I was wondering if anyone had the wheel spec chart? I cant seem to find it. All I have found were ones for 18s, 19s, and 20s. Anyone happen to have one for 17s? I would greatly appreciate it if someone could send me the chart.
Thanks guys. -Andrew |
17" VS-KF's are no longer in production. Its bittersweet because you have a rare set of wheels which will bring up the value of your set, but it will be hard to source replacements.
www.metalpolishpro.com |
#3 | |
no one has happened to save a pdf of the 17in wheel specs? =[ Thanks for reading everyone. |
![]() Join Date: Apr 2007
contacting Work won't do much. I was wanting to know the available sizes of the 17" VS-XX and i contacted them, and a few major Work Wheel vendors and no on really had the information, or was willing to GIVE out the information. I did find a link showing the sizes of the VS-XX Work VS-XX Wheels from Upgrade Motoring so i'm assuming you can google and find the sizes of the VS-KF
EDIT - HERE http://www.mynismo.com/products/Defa...id=4588&v=more and http://www.rhdjapan.com/work-vs-kf-wheels-53423
Well if you are keeping the barrels and faces the same, then it should just be a matter of chosing which lip size you want. I don't know what a wheel sizing chart is going to tell you>? I would probably do no more than 2.5" if its on metal fenders, but obviously what width tire you want to run is going to have an affect here too.
Thanks so much! |
#8 | |
-Andrew |
![]() Join Date: Sep 2006
damn you turned your KFs into 3 piece!? thats the shit. let us know how much the bill is at the end, if you dont mind?
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
#11 | |
I am getting the wheels back within the next couple days and I am quite excited. They will be 17x11+19. hope this helps. -Andrew |
damn. i shyed away from buying KFs because i couldnt disassemble them myself to swap out the lips. but the stud & cut job isnt that much at all. i might start buying kfs now.
![]() Join Date: Aug 2009
Trader Rating: (55)
![]() Feedback Score: 55 reviews
damn 17's in that sizing kinda sucks way to big for s chassis evey if widbody that'd probably hit inner walls in rear, also it takes about 2-3weeks .
yes maybe for an S chassis.. but i drive an FD with widebody which likes deep inner barrels and can run decent sized lip. =] As far as wait time, they tackled my pair of wheels in about 3-4 days max to do all of that. =]
many people shy away from kfs for this reason. I wanted to give a good description on what has to be done in order to make this a true three piece wheel because through all my searching, no one has ever gave much information on KFs. Hopefully this will help people in the future that will want to relip their VF KFs. |
![]() Join Date: Jan 2010
Trader Rating: (26)
Does anyone know where to get replacement bolts for them? I've googled to try to get the proper sizing and hit up WORK but never got a response. If anyone can point me in the direction to get some, I'd be much appreciated.
