#31 |
![]() Join Date: Oct 2012
No it did not come quite that way but quite Nice. Redone and made to fit 90mm bore/ 2,2 liter
Don't PM me asking for parts |
#37 |
GTiR ITB's does not even fit a bit to the head, Had to fabricate to make it work, and tons of porting of the ITB's to make them work.
Here is a picture of a original/stock BTCC engine Ports are twice as large as any normal SR head, Janspeed/ Nissan spent 36 million GBP back in the 90s to make the engine for the BTCC cars produced upto 340 BHP naturally aspired as a 2.0
#38 |
what so special about the head? ports dont look that big
ports look the same as any other sr20de/sr20det cylinder head i just dont see what makes that cylinder head so much better then any other sr20de/sr20det cylinder head |
#39 |
it's diffrently build than a regular sr20de head. Think of it, they made up to 340 BHP as a 2.0 natural aspiration engine, try to make that with a a stock SR20de head!
its a bit different built up and the ports are about twice the size areal or a sr20de head + valves guides and such is not regular. Flows unbelivable good, and when youhit up a turbo on this there is crazyness happening, could not done the same with a normal sr20de head at all.+ there was made about 34 of them, and I heard there is about 12 left, which makes it pretty special itself. it's a lot of tech inside, ofc on the outside it looks normal, it isnt always the outside look that tells you everything you know the BTCC engines and heads were produced by Janspeed UK on licence from Nissan. At first Tomei was chosen to make this but they failed so Janspeed took over
#40 |
i just dont understand why u would go through all that work when a ve head is the same amount of work and is a better performing cylinder head
there is no way those ports on your cylinder head is as big as a ve cylinder head and there is no way the valve train design is any where near as reliable as a ve cylinder head like if your going to go through all that work make it worth while and use the best cylinder head u can get your hands on and the best cylinder head for any sr20 block is a P12 sr20ve cylinder head |
#41 | |
a VE head isnt better because it flows better, which I doubt, but only due to the fact you have VVL that gives you power over a bigger range and earlier spool which is rather important if you ask me.
OakHeart Racing |
#42 | |
the ve head not only flows a shit load more it has a more reliable valve train the rocker arms are held in place with a rod which runs from one end of the cylinder to the other end holding the rocker arm in place it doesnt matter how hard you rev the engine the rocker arm isnt going to pop off sr20ve ports against sr20de/sr20det ports |
#43 |
You guys are crazy for criticizing him on this. It's a head and it's a damn good one at that. Why don't you just ask him why he isn't putting a V8 in it?
* S14SR22 * 9.0 c/r * GT3071R * |
#44 |
I've never heard of much issues with Valves and such on DE heads, however, I know for a fact that a VE head is better due to the fact that it's variable, meaning earlier spool, meaning wider possible RPM spectre to play with.
However the peak output, I doubt there will be any difference whatsoever. I'm for the VE head, but unless he wins the lottery, the plans won't really change. if money wasnt a issue the build would have been done by now :P
OakHeart Racing |
#45 | |
Thank you, I am so glad there is people like you here! For information: If I wanted to have what a VE head can give me that the BTCC head won't I would ofc used the VE head. And saying that your VE head flows "shit loads more" than my BTCC head then I think you would have to come here and see. VE was developed during 1996 and If it was any better, Nissan would have used that, and not the DE to win the BTCC championship with their primera. The BTCC isnt a normal SR20DE head, it was in fact made with more material around the ports so that the ports could be as a large as possible. Do you think your stock VS head would beat a stock BTCC head as N/A engine? I don't think so Valves are also slightly larger + these engines could do 9500 rpm, no problem! Without having issues with rocker arms etc. + of course i have custommade rocker arms in a different material than those of a regular SR20DE head... + there was made like 34 engines for BTCC, so no, I'd not rather throw my DE head and pruchase a regular VE head. Also, you mentioned the ports were small compared to a VE? I don't think so! Today's Update: Finally got some more Argon gas for my TIG welder so I could start welding some more on the plenum, got almost finished but it's not yet complete. Still waiting for some new bolts that would fit for the special holes in the Meziere waterpumps. Also came to the decision today that I am going to make the whole suspension setup myself together with a mate which works with delivering to the sportscar industry racing. Of course Coilovers I will not make myself But mostly everything else. Going to use a very solid metal used to aircraft industry + lotsa uniballs. Everything will be adjustable. + going to machine some 50mm spacers so that the car will handle a bit better in the rough corners with higher speed. For tires I am hoping to maybe get some 285 fitted under there
#46 |
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
Don't worry about all the people saying do a VE. I myself actually am doing a stroked VE, but i love seeing rare/new/extreme swaps. I personally get tired of the same old basic swaps, but hey to each his own with his own money
also, great job on the build so far.
https://instagram.com/eck_matthew/ |
#47 | |
Flow tested the head of mine to a lot over 1000bhp Lift is have is 13,1 so will be getting enough air in hehe, a ve head would never beat the btcc head. Doing some small stuff every day, minor parts but its often the most time taking. Like alternators adjusting, making newparts and such. Will post up some pics during the weekend of new smaller things that has been done. Yesterday I was in sweden, picking up the new cylinderhead for my brothers Volvo 242 16v. Quite extreme that too.
#48 | |||
#49 |
mate your dreaming if you think your BTCC cylinder head will out perform a ve cylinder head
im not doubting your BTCC cylinder head isnt better then a sr20det cylinder head but i doubt it will out perform a ve cylinder head i just think your making a BTCC cylinder head out to be better then it actually is micks motorsports is running into the 6 second bracket with a ve head ben bray is running in the 7 second bracket with a billet block ve head Dps imports is running in the 7 second bracket with a ve head There is more but that's all I can remember off the top of my head Last edited by STR8E180; 01-21-2013 at 04:01 AM.. |
#50 |
![]() Join Date: Feb 2012
I'm going to have to side with str8e180 on this one.. Although, I promise I am not criticizing your decision because in the end it is YOUR build and not ours. Your ports do look massive when compared to factory de ports, but there is no way you can truthfully say that a ve wont out-perform the btcc head. The ve is the be all, end all for the sr20, hands down. Not only are the ports larger than the btcc's in stock fashion, but variable lift and valve timing make it even more amazing. You could do all that nice porting to the ve head just as you have for the btcc. The shaft mounted rockers are the best design for the sr20 by far. No matter what you do you will have problems with the rockers un-mounting themselves at high rpm. A dual guide shim setup is the next best thing, but still it doesn't compete with the ve head, which Mazworx uses to rev out 13k rpm.
I love this build and I think it will shake the earth when it hits the track, but there is no denying the ve head's performance despite the rarity of the btcc head. This build will be different and I applaud that. I look forward to seeing the finished product. It is on a completely different level compared to most of Zilvia's builds. Keep up the hard work! |
#51 | |
That's exactly my point |
#52 |
Point is that I don't even care a little if XXXXX runs low 4 secs or xxxxxx runs low 5 sec with a billet VE head, i'm building
I'm not building this car for any specific class or racing series, Will do some timeattack but still want to maybe try other things. I know VE is a good head and that it performs well, If i wanted one I would already had one. Thing is, I want this car to be different from everything else. When you think of a 200sx/240sx/S14 within racing/motorsports, the picture is a sliding driftcar. Here in Norway, I have never seen a Grip/timeattack Silvia IRL all those years, so thats why I bought it, make a grip car be different. When tinking of SR2X engines and tuning, everyone does a VE swap, I thought "hey, I'm gonna do it different" So what is more different than a GRIP Silvia with a DE head ? At least here where I live its nothing I've ever seen. you can call me a sick fuck with a disturbed brain but I like doing things different and spending much effort to even the smallest piece of the car. I could probably sell just the BTCC Magnesium Valvecover itself to a museum or collector and buy a complete VE head for the money I could get for it. Last update pic lol 58mm port, still having clearance to waterports etc and btw the btcc primeras did up to 10500 rpm and didnt have any special rocker arm troubles, + the DE sr20 won the total BTCC in the late 90s. And please don't doubt me on this, this thing I know Peace
Don't PM me asking for parts Last edited by Teigen; 09-08-2013 at 02:09 PM.. |
#54 |
Trader Rating: (18)
I agree, keep the updates coming! Most of the haters are just people who can't even afford to do a proper build...so they hate on people who can. keep updating for the guys like us that actually like to see new and extreme things being done!
#55 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Keep that valvecover!! Don't listen to those jagaloons man, run the btcc head. There is a reason most people go with the ve head, since there are only what 12 btcc's left? I tell ya what, if I was building an sr, I would choose that same head. No questions asked. Awesome build so far man! Keep up the work!
#56 |
Hey me and str8e180 both agree'd that it was different and that it was a great build. The ONLY thing that was criticized was you saying it was better than a VE head. I personally told you I loved the build and how different it was.
If you just lost motivation for the build because someone said that a ve head would have been better then you should give your wrenches away for good. Get a grip man. It's a fucking forum. I thought you were a good sport, but if you wanna whine and cry just have them delete it. No room for people getting all butt hurt around here. |
#57 |
Mate u seriously need to relax it up a bit aye
Why are you gettin all upset for ? No one is hating on your build just because I said a ve head is better then a btcc head does not mean I'm hating I'm just stating fact Sorry not every one is yes men some people might actually want to tell you the truth It's the truth and if u can't handle the truth then Internet forums arnt for you I love the fact your doing some thing different it keeps your build interesting but don't go saying your btcc cylinder head is better then a ve head when clearly it isn't and if u think it is then you need to do your research All I was doing was correcting what you throught was right Like I said before I love the fact your doing some thing different I was trying to work out why you were doing all this when There was a better option out there and i now know why its to be different If that's what u want that's fine Some people build cars to be different there's nothing wrong with that Last edited by STR8E180; 01-21-2013 at 01:24 PM.. |
#59 |
Shaft mounted rocker arms
Standard ports flowing 300cfm in standard form I know of billet aftermarket heads that don't even do that VVL What's a btcc cylinder head got ? No VVL, it doesn't even have VTC, no shaft mounted rocker arms, ports are clearly smaller It's not hard to work out which is the better cylinder head The ve head change The game for sr20's Scorch s15 very impressive time attack circuit car which holds the record at 52 seconds around Tsukuba circuit track in Japan Now take into account this rear wheel drive car is faster then 4 wheel drive cars MCA s13 fastest rear wheel drive car at World time attack in Australia placing in at 3rd There are 4 or 5 drag cars running in the 7 second bracket and micks Motorsports running in The 6 second bracket All these cars run sr20's and what do they have In common they all use ve heads Its the most responsive cylinder head due to its VVL and massive ports It's the most reliable cylinder head due to its shaft mounted rocker arms The amount of extra timing my engine took after the cylinder head conversion was amazing My tuner said its more like tuning a Honda then a Nissan My car makes 300kw on 10psi at 4000rpm how many sr20's do u know of that can do that ? |
#60 |
You realize none of what you just posted amounts to proof, right? Just because a certain drag car runs VE heads and makes a bunch of power doesn't mean shit because you have nothing BTCC to compare it to. And just because all those builders use VE doesn't make it better, maybe they just couldn't find a BTCC head because there are like 12 of them...
At this point I am not even picking sides, I just letting you know that you cannot argue anything about which head is better because you haven't seen both in action with similar spec'd motors. The fact that a new head was built at all when the VE was readily available should be proof enough for you to wait this build out and see what kind of numbers it makes. \end bashing please continue build thread ![]()
| btcc, s14, tremec, turbo |
