Manual 1998 240sx Kouki SE
For Sale: 1998 Kouki 240sx
Passed smog in January of this year. A/C blows super cold. Regularly maintained. Runs Great. Going out of state next month and can't take the car with me. Price is SOLD I am open to trades for a sedan (Corolla, Camry, Sentra, etc...) Since this is my daily driver I need to sell it between August 1st and August 10th Call or text: (626) Two33 75six0 Mileage: Engine: 48,000 Chassis: 248,000 The engine was rebuilt at around 200,000 miles on the chassis. Here are some of the details of that rebuild: Ka24de NA 3 Angle valve job Ported intake manifold Jim Wolf S1 cams Nissan Motorsports valve springs ARP head studs Feltpro gasket Kit Circuit Sports thermal intake manifold spacer Brand new OEM Nissan timing chains, guides, and tensioners Brand new OEM Nissan oil pump and water pump Brand new OEM nissan water temp sensors and coolant temp sensors F1 Motorsports Chromoly flywheel and stage 1 clutch Nismo slave cylinder Manual Swapped Transmission Intake/Exhaust/Cooling: Isis Dual Tip cat-back exhaust DC Sports Short Ram intake (with CARB sticker) Mizu Aluminum radiator Dual E-fans Circuit Sports overflow resevoir Suspension/Brakes (All of these were replaced recently and have less than 10,000 miles on them): Fortune Auto 500 Coilovers with Swift Springs 8k/6k SPL tension rods SPL traction arms SPL outer tie rods with z32 inner tie rods Energy Suspension Sub-frame Bushings Circuit Sports rear upper control arms (only components with more than 10,000 miles on them -- Still in great condition) Q45 Front Brake swap (new calipers from R1 Concepts) R1 Concepts Front and Rear drilled and slotted rotors Drivetrain: Thorough Concepts 1 piece aluminum drive shaft S15 Spec-R Helical Differential Exterior: Full Generic VIS body kit (with front fenders and rear over-fenders) Megan Racing rear roof wing Street faction front bash bar Varrstoen Es2 9.5" Front, 10.5" Rear Interior: Nardi 330mm deep corn leather wheel Nismo Titanium 350z shift nob (sticker says 6 gears, don't be confused if you see it) Stock S14 SE seats, carpets, trim Great Condition Dash has a very minor crack that is not visible from the drivers seat 12" Memphis Subwoofer with Memphis box Full sized stock spare tire Cons: Body Kit fitment isn't great Bumper has some stitches Engine light is on with 3 codes (no affect on how the car runs): P0705 Transmission Sensor (Normal from a manual transmission swap, the sensor is no longer connected) P0440 Evap Emissions System P1447 Evap Purge Flow Reverse light doesn't work Last edited by Swagless; 08-11-2018 at 06:03 PM.. |
