Old 01-08-2009, 09:26 PM   #1
jeb
jeb's Avatar
jeb is an unknown quantity at this point
SR wanting to build up s14 sr20det
i have a s14 sr an thinking about rebuilding it an this is my first time ever doing this so i would like some pointers and ideas. im wanting to get around 350-400whp out of it an keep it reliable.
jeb is offline   Reply With Quote
Old 01-09-2009, 05:07 AM   #2
Monooxide
Monooxide's Avatar
Monooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to behold
Realistically you don't need a rebuild for that kind of WHP as long as your compression is good. I would get a metal head gasket and maybe some ARP head studs and call it a day.
If you however still want the engine rebuilt I would reccommend Mazworx.
Monooxide is offline   Reply With Quote
Old 01-11-2009, 08:02 PM   #3
Hawaiian240
Hawaiian240's Avatar
Hawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud of
s13
A good tune will do wonders also! The money spent will be cheaper in the long run, instead of rebuilding the engine again!
This thread should be a good start
http://zilvia.net/f/engine-tech/62607-sr20det-faq.html
Search for other members builds. See what kind of numbers they are getting, power band, and what parts they used to get there. If it is similar to what your goals are, build yours based on theirs.
Find a reputable shop close to where you live so you can get it properly tuned.
Hawaiian240 is offline   Reply With Quote
