| Stolen Goods Report stolen cars, parts, girlfriends, etc. |
**stolen rx7 =(
hey guys. my rx7 was stolen from my diveway this past week. Please help me spread the word so that hopefully it can be retrieved.
PLEASE help spread the word to keep a look out for a possible combination of parts from this car being sold anywhere. LET ME KNOW ASAP so I can call the authorities. (856) 332-5417 I may not check back often enough so please use my number. I receive text and calls. THANK YOU! heres a list of stuff on the car from the for sale add MOTOR -Brand new Series 5, 4 port turbo crate motor $4,800 (stronger motor, thicker iron) -T4 Borg Warner s363 extended fin turbo $1200 (new) -Custom divided long runner stainless steal manifold $800 (new) -Tial Q bov $280 (new) -Tail 44mm waste gate $360 (new) -Koyo 53mm aluminum radiator $305 (new) -Greddy front mount inter cooler $949 (new) -Black Magic electric fan shroud $299 (pulls in lots of air. best on market) -Racing Beat full exhaust $1049 -Microtech lt10 ecu $1,100 (new) FUELING -KGParts primary & secondary fuel rails (new) -Aeromotive Fuel Pressure Regulator (new) -Summit A/N fittings (new) -Summit -6 fittings (new) -Stainless steel lines (new) -Bosch 1680cc secondary injectors (new) -850cc primary injectors (new) -Stainless steel fuel lines (new) $1,200 for kit -Supra tt fuel pump $120 (new) DRIVE TRAIN -Act 6 puck clutch -lightened 9lbs flywheel -Jegs short shifter -S4 clutch type lsd (strongest of all generations and rebuild-able) INTERIOR -OEM black S5 rubber center console -OEM black dash, toggle, switches, bins, door panels ect -New OEM carpet and headliner with thick foam padding -New high quality heat and sound deadening material -Corbaeu A1 micro suede seats -SFI approved 5 point seat belt harnesses by Corbaeu -Grant Steering wheel STIFF STUFF -Jegs 8 point roll cage (previous owner installed) -Racing Beat front and rear sway bars -Tokico Blues with HP springs EXTERIOR -Highly sought after GP Sport body kit (genuine. not knock off) -JDM S5 tail lights with removed reflectors and smoked for modern look -JDM side markers with LED -JDM front day time running lights with LED (USDM models used a cheap design one piece head light projector) -17" Enkie black RFP1 wheels (tires @ 80%) |
![]() Join Date: Jan 2010
did you have a car alarm?? when I go back east...... oh man
im going to newark today to buy a shitton of tires. ill def be keeping an eye out
