![]() Join Date: Mar 2009
S13 SR20DET Black Top Part out
More parts listed if you do not see it ask about it.
Located in Louisville KY, I am parting out most of a S13 SR20DET Black Top. Let me know what you want from it I may have it. I will post more details and pictures later. ARP Head studs 3k miles old you will need to use your harden washers from your head studs, $20-SOLD Wiring Specialties S13 SR20DET into S13 great condition $250- SOLD Rocker Arm Stoppers for Nissan SR20DET $40 OEM Rocker Arms for Nissan S13 SR20DET $15 each cas $100 power steering pump with bracket $100 -SOLD alternator $100 alternator bracket - $50 O2 sensor $50 radiator $100-SOLD SR20DET OEM Flywheel $60.00 IACV $75.00 Bare Throttle body $25.00 - SOLD 5 Speed TPS $35.00 -Sold 5 Speed transmission $350 Coilpacks $120.00 OEM Fuel rail with FPR $30.00 OEM upper oil pan $30.00 OEM lower oil pan $30 SR20 Crank pulley $50.00 (Freshly machined from the machine shop) 5 Speed transmission plate $25.00 Valve cover $50- Sold Thermalnator Intake Manifold Gasket $25 -Sold SR20DET block $50 (needs to be sleeved) (May turn into a coffee table in the man cave if no one wants to use it) New in the box ACL Race bearings .25 over for the Rods $40 New in the box ACL Race bearings .25 over Main bearings $60 Pair of OEM nissan thrust washers $5 or free if you buy the ACL bearings. o2 housing and down pipe Pending, o2 sensor has about 3000 miles on it and is still available. tuned ecu; set up for 740cc injectors, z32 maf, GT2871 turbo, made 417 whp on a dyno. Freshly machined Crank $200 OBO Alternator $100 Alternator Bracket and hardware $50 OEM fuel pump with FPR $30 Oil filter housing, I have 2 of these $20 each Lower Oil Pan $30 ebay no name wastegate $10 Timing set with 3k miles on it $30 Water neck $30 Turbo inlet and outlet $50 Crank Pulley $50 CAS $100 Power steering pump $80- Sold Power steering Bracket $50 - Sold or both pump and bracket $100- Sold Coil packs $100 for the set or $30 each Coil pack sub harness $30 Starter $100 Lower Harness $75 Pending Blitz BoV $125
Do you need; Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill S13 Silvia J's, Q's, K's, A's Bumper grill inserts. Male Plugs for S15 headlights PM me if you need them. Last edited by LuckyRPS13; 09-23-2014 at 07:06 PM.. |
If you see Parts no listed and you are interest PM me.
Do you need; Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill S13 Silvia J's, Q's, K's, A's Bumper grill inserts. Male Plugs for S15 headlights PM me if you need them. |
All PM's Replied to.
S13 SR20DET into a S13 body. it will work with all the S13 SR20DET ecu's
#9 | |
I will shoot you a pm. Text any time. I am awake at random times...
Bump! some stuff sold some pending Make me an offer nothing reasonable will be refused!
Cam gears,
PS pump with the bracket, Maf All sold and shipped today.
PM you about the Head studs.
#17 |
I have a SOHC KA Harness you could pull the pig tail you need from it. but I would ask $25+shipping for the harness since that would ruin it. Or $25 and I will seperate the Maf wiring and send just that to you.
#19 |
Last bump before new thread
#20 |
I had a PM for this thread, just a heads up all of this is sold now
#22 | |
