Help Please. RB25. No start.
Ok guys I've done alot of searching and havent found what Im looking for.
I have an RB25 swapped S13 thats ran fine since Ive had it. (only 1-2 months) Suddenly, Alot of problems came my way. It all started when I began blowing fuel pump fuses. After 2 blew I put in a larger amp fuse and they stopped blowing. But then, My spark plugs went out. After figuring out the plugs were bad I replaced them and it started right up. I then drove the car about 20 miles and the EGI Relay and/or the EGI pump went out. I replaced these and drove the car for about 30 miles as a test. Parked the car overnight and now it will not start. Again. Any help would be greatly appreciated as I've spent over $200 in tows home in the past 2 weeks. Car is cranking fine like it wants to start its just not catching. Fuel pump only primes sometimes. Thanks guys. Ok after letting the car sit for about an hour I went out and it started right up. There was a change of about +15 degrees outside during this hour. Could that have anything to do with starting? Last edited by SILF0RTY; 08-09-2010 at 08:51 AM.. Reason: Car Started. |
![]() Join Date: Dec 2006
first off installing a higher Amp fuse will fuck more stuff up and possibly start a fire in the car.
Find out why the fues's are blowing and fix that issue, then pull codes from the ECU, might be a sensor thats going out. Possibly one problem is the CTS (coolant temp sensor)
