![]() Join Date: Sep 2010
FT: 1990 s13 Silvia wannabe
****Car is gone
I have decided that I need a different car for the next couple years. What I have for trade is a 1990 240sx with a CLEAN title in hand. The car has a rebuilt Red top SR20det. The the engine was rebuilt with OEM Internals (pistons, conrods, crank was balanced and polished) and reinforced with ACL race bearings, metal head gasket, ARP head studs. The car is lowered and has a stealthy look. What do I want? Something a bit newer, pretty much stock (coilovers, wheels, etc are fine), with A/C, and 5 Speed. If you have something that has less value than my car then put cash on top of your offer. I don't want something that is unreliable or a project. Edit: I have pretty much decided I want a clean kouki s14. Details: Updated Compression Numbers (Tested 12/30/11): Cylinder 1: 165 Dry, 190 Wet Cylinder 2: 160 Dry, 185 Wet Cylinder 3: 160 Dry, 180 Wet Cylinder 4: 160 Dry, 185 Wet Engine: Sr20det Red top from S13 circuit sports intake manifold gasket nismo fpr turbo xs exhaust manifold stock turbo with adjustable waste gate and custom bracket S15 motor mounts S15 turbo manifold gasket greddy hot pipe ARP Head studs, rod bolts, main studs custom grounding kit that works great individually gounded coil-packs Cometic Headgasket ACT street clutch rated at 362 ft lbs and light weight flywheel Head has been decked as well as the block the head internals have been replaced with new factory bolts, valves, retainers, and valve seals, and lifters GT Spec Down pipe 3" FULL mandrel bet exhaust with Magnaflow muffler (Stock look) Yashio factory radiator New coolant temp sen NGK Spark plugs (Heat range 8) GREDDY airinx intake Good year gator back belt NEW oem oil and water pump NISMO thermostat 300zx fuel filter Lighter alternator pulley HKS Super sequential BOV Suspension: D2 coilovers Tein tension rods peak performance rucas peak performance rear toe arms energy steering rack bushings Viscous LSD with 5 bolt axles and 4.1 final drive nismo clutch pivot aftermarket inner and outer tie rods 5 lug conversion with Stock Z32 wheels (NEW hankook Ventus v12 tires) Brakes: 300zx front calipers with drilled and slotted rotors with ceramic pads rear brakes jst received new rotors as well as Bendix ceramic Steel braided brake lines Exterior; Black sapphire metallic off of BMW 7series OEM Metal Nissan front-end OEM Dual projectors Headlights 8000k HID Interior: One single crack on the dash. It just happened so its not huge like most. Nismo shift nob Sony Stereo with I pod connect Greddy Boost gauge S14 front seats New front windshield New parts installed within the last 4 months: Brand New NSK front passenger side wheel bearing Brand New optima relocated to trunk with lifetime warranty Brand New z32 brake master cylinder with lifetime warranty Getting a rebuilt starter with 1 year warranty Cons: If you are picky like me, you will notice the hood is not perfectly aligned near the driver side headlight area. No A/C Small crack on dash. The only differences in the car now from the pics is that I have 18mm bolt on spacers in the front and rear, and I have the oem steering wheel in now. Last edited by lude4life13; 01-03-2012 at 02:02 PM.. |
trade for s14?
#/f/cars-sale/411404...d-cold-ac.html |
![]() Join Date: Apr 2007
Was this car from HB?
Engine bay pics?
#/f/traderratings.html?u=57636 If i sold you something or gave you it for free post here! Thanks! |
